NEXT YEARS SET-UP/ WHAT SIZE TURBO?
Old Dec 2, 2006 | 06:37 AM
Drkaccrd's Avatar
Default NEXT YEARS SET-UP/ WHAT SIZE TURBO?
Im looking to achieve around or at 400hp with my set-up.
built/sleeved h22..etc,etc
what size turbo should I get to achieve this with the lowest boost possible? (10-14psi)
Ball bearing is an option to get it spool fast and keep the low end as usable as possible.
Old Dec 2, 2006 | 06:58 AM
2point2's Avatar
Default Re: NEXT YEARS SET-UP/ WHAT SIZE TURBO? (Drkaccrd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drkaccrd &raquo;</TD></TR><TR><TD CLASS="quote">what size turbo should I get to achieve this with the lowest boost possible? (10-14psi)</TD></TR></TABLE>
subscribed.. but,
Why do you want the lowest boost possible for x amount of hp with a built block? You should be asking for the 'best powerband possible' for x amount of hp.
Maybe I'm wrong, but I just think of an oversized turbo with a poor powerband when high hp and low boost go together.. someone correct me if I'm wrong!
Old Dec 2, 2006 | 07:03 AM
Drkaccrd's Avatar
Default Re: NEXT YEARS SET-UP/ WHAT SIZE TURBO? (2point2)
I only said that I wanted the lowest boost at that HP because Ive seen others do it and achieve great low end TQ numbers.
Old Dec 2, 2006 | 07:24 AM
HNLV's Avatar
a "TE 61" from turboelements.com will get you to your goal no problem at all. Call Tim
Old Dec 2, 2006 | 07:38 AM
DaveF's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drkaccrd &raquo;</TD></TR><TR><TD CLASS="quote">I only said that I wanted the lowest boost at that HP because Ive seen others do it and achieve great low end TQ numbers.</TD></TR></TABLE>
on my 1.8 ls/vtec - t3/t67 ho. i was able to make 445hp/315 torque through a 2.5inch exhuast. on pumpgas (18-19psi of boost)
Old Dec 2, 2006 | 07:41 AM
miller's Avatar
Default Re: NEXT YEARS SET-UP/ WHAT SIZE TURBO? (dturbocivic)
expletive it 42r FTFW
Old Dec 2, 2006 | 07:42 AM
DaveF's Avatar
Default Re: NEXT YEARS SET-UP/ WHAT SIZE TURBO? (miller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller &raquo;</TD></TR><TR><TD CLASS="quote">expletive it 42r FTFW </TD></TR></TABLE>
seriously hahah go big or go home
Old Dec 2, 2006 | 07:59 AM
Drkaccrd's Avatar
Default Re: (sqeezincheeser)
are any of the bigger trims available in a 5bolt ?
Old Dec 2, 2006 | 08:12 AM
Schister66's Avatar
Man U FTW
i dont get the reasoning for the big turbo low boost desire, but personally i would rather sacrifice a little torque up top and have a better powerband all around....GT35/40R
Old Dec 2, 2006 | 08:27 AM
Drkaccrd's Avatar
Default Re: (Drkaccrd)
Well the reasoning behind that was to achieve my goal and have plenty of room left to up the boost later. Just thinking ahead!
Old Dec 2, 2006 | 11:06 AM
a1320addict's Avatar
I would definently get something that gives you a little room to grow with, because you'll get bored of the 400..lol. Especially when you have a built block to take advantage of
Old Dec 2, 2006 | 12:20 PM
Drkaccrd's Avatar
I know theres gotta be some turbo h22 set-ups out there thats met the set up I'm looking for. Any others out there? So far the TE 61, gt35r & gt40. The gt42 sounds like its way too much.
Old Dec 4, 2006 | 03:21 PM
Drkaccrd's Avatar
does anyone have dyno pics of the t61 on a built h22?
Old Dec 4, 2006 | 03:24 PM
Drkaccrd's Avatar
nevermind I found some......
Prudz_lude
Jan 21, 2013 08:00 AM
marcussmith26
Dec 20, 2005 12:10 PM
CroteTurbo
Aug 23, 2005 08:17 AM
duiwrx
Jan 11, 2005 11:57 AM
NightHawkC5
Jan 10, 2003 07:40 AM
