Turbo psi w/ diffrent turbo
Lets say u are running 8psi on a Gsr with a t3 turbo and u get a t-25 instead can u boost more now safely because of the smaller size like 11? Also it will spool up faster but will it sacrific top end?
[Modified by NightHawkC5, 8:47 AM 1/10/2003]
Re: Turbo psi w/ diffrent turbo (NightHawkC5)
Actually no.If you go to a smaller size you won't make as much power; do to efficiency levels going to sh!te. You'll heat the air too much.
but can i boost more with a bigger turbo
more then just turbo size....
