what is this set up capable of
t3/t4 trubonetics bb 50 trim with cast mani.. rc 550s tial 38 mm wastegate greddy bov 2.5 in piping and a 500hp intercooler... on a stock internal lsvtec.... what should it spool at running around 14 pounds or so i wanna make around 350 on pump should this be a problem... and what would the rev limit be on a stock lsvtec....i hear they cant rev high with stock rod bolts... thanks alot
Modified by lsvtechatch92 at 11:12 PM 11/19/2006
correct upgrading rodbolts would be good on a lsvtec setup
however your compression ratio might hurt you i feel on a good compression lsvtec you might only be able to run 10psi, but depends on how high of compression, i think 300hp is reachable. with a good tune
but you also cant just go changing rodbolts out wither without rebuilding the bottom end
smcowman
Dec 8, 2008 02:17 PM
