D16Y7 TO D16Z6
From: So Cal where old pople try to race you, U.S.A
are you using the y7 ecu? if not it till not run correctly because the iacv's on the y7's are 3 wire and the y7 does not have vtec.
I HAVE ALL PARTS THAT I NEED. ALL I NEED TO KNOW IS WHAT TO DO WITH THE WIRING. I HAVE A P28 VTEC ECM. WE GOT THE CAR TO START IT IS JUST HESITANT WHEN YOU TOUCH THE GAS AND THE TIMING IS ON.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bense »</TD></TR><TR><TD CLASS="quote">obd1 p28 or obd2 p28?</TD></TR></TABLE>
i hope thats a trick question buddy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaman156 »</TD></TR><TR><TD CLASS="quote">GOT IT TO START NOW WERE READING CODES
14-IACV(intake air controll valve)
20-ELD(Elec. load detector)
22-VTP(vtech pressure switch)
any help??</TD></TR></TABLE>
vtech??? VTEC
vtech??? VTEC
Did you do the IACV connector fix in the engine bay? Y7's used a 3-wire IACV and Z6's used a 2-wire. Did you wire up VTEC? Y7 engine harnesses don't have the wiring for it in stock form.
stw88crx
Nov 10, 2004 01:24 AM
