camshafts and cam gears question?
Old Nov 10, 2006 | 12:24 PM
jrs2ksi's Avatar
Default camshafts and cam gears question?
I got a 2000 honda civic si with around 180 hp. I was wondering how much power i would get out of aftermarket camshafts and cam gears. I was thinking about just running tru time AEM gears.......so would it be better to do camshafts too? Any advice would be great. Thanks a lot.
-Jordan
Old Nov 10, 2006 | 12:31 PM
jrs2ksi's Avatar
one more thing too. I have the stock cover on my b16. can i trim the side of the stock cover to expose the gears? I like that look when u can see the gears when there anodized?
Old Nov 10, 2006 | 12:47 PM
white ex's Avatar
Default Re: camshafts and cam gears question? (jrs2ksi)
just adding adjustable cam gears will not give you power you have to adjust them to achieve the optimal timing.
Old Nov 10, 2006 | 01:15 PM
doood's Avatar
been there done that
Default Re: camshafts and cam gears question? (white ex)
what mods do you have that make you think you have 180hp? any dyno sheets?
anyway back to the op, how much power you get from cams depends on the cams, other mods you have, and the tune. as for cam gears, get something with easily read timing marks and more than 3 bolts. i like the golden eagle gears.
sure you can trim the side of the valve cover and timing cover to expose the gears, but if you plan to daily drive it like that a small rock or anything could get in there, and then.....your screwed.
Old Nov 10, 2006 | 01:25 PM
jrs2ksi's Avatar
thanks. well i dont know for sure how much hp i have. I know stock they have 160. I have dc headers, AEM cold air, custom exhaust all the way back, throttle body and pullys. So tunning the gears is just by adjusting the bolts at the degree marker, right? Or do i need to take it to a shop?
Old Nov 10, 2006 | 01:32 PM
doood's Avatar
Default Re: (jrs2ksi)
you're putting down 130-140whp at best. you tune the gears on the dyno so you know if the adjustments are making any difference.
Old Nov 10, 2006 | 01:38 PM
jrs2ksi's Avatar
Default Re: (that one doood)
yea im gonna have to get my car dyno'd. I thought i was get more whp then that. Well i think im gonna order the AEM true time gears. I have to take my car in to get it serviced soon so i'll have my mechanic tune it up. thankx
Old Nov 10, 2006 | 03:35 PM
MurdersV8s's Avatar
Doesn't the AEM cam gears have three bolts? Like what that cool doood said get cam gears that have five or six bolts. I have heard stories about AEM gears slipping and when thta happens you're screwed.
Old Nov 11, 2006 | 06:33 PM
stealth50k's Avatar
Default Re: (MurdersV8s)
I think it will make a difference tuning wise, but will not increase power if their is nothing to tune.
Old Nov 12, 2006 | 01:21 PM
jrs2ksi's Avatar
Default Re: (stealth50k)
yea my bad, the AEM gears do have 3 bolts. I will definitly go with gears that have 5 bolts. thanks guys.
Old Nov 12, 2006 | 01:29 PM
Syndacate's Avatar
160hp is a flywheel hp number, the car's really puttin down about 120-130 at the wheels, maybe 130 to 140 with your boltons.
BHP = WHP =/= HP
Your car has to be tuned once you install the camshafts, get them tuned on those adjustable gears and you may be good for an extra 5whp or so.
Now when you get ready to flip out on me and tell me ur car's really got 170 and the cams will give u 20 more I only have one thing to say:
Don't hate tha playa, hate the game.
EDIT:
PS: Yeah, you can just trim down the side if you want the cam gears visible, it's just a guard so some dumbshit doesn't get his finger taken off while working on a running car, shouldn't have any problems there. Though it also keeps any **** from getting in there, it's a "saftey" feature for your engine..but if you have **** going in there you probably have bigger problems to worry about.
Old Nov 12, 2006 | 01:58 PM
SkoundrelUSA's Avatar
cute little bastard
Here was my old B16 setup. A good reference for you I guess or should I say don't get your hopes up lol. I made 174whp with everything tuned with a VAFC. And ran 14.7 with a 2.3 60ft in a 2420lbs with driver car.
https://honda-tech.com/zerothread?id=1622528
1998IntegraLS84
Jul 24, 2005 06:55 PM
hondamanwill
May 29, 2003 08:15 AM
ModAddict
Feb 4, 2003 02:05 PM
nerdish
Mar 3, 2002 08:44 PM
rockwilda
Dec 31, 2001 02:32 PM
