Distributor Help!!!!!
Old Nov 9, 2006 | 05:54 AM
JDM Like Whoa's Avatar
Default Distributor Help!!!!!
Ok, my car is stranded, need to know this ASAP.
Will an OBD1 LS distributor work on a GSR?
Old Nov 9, 2006 | 06:22 AM
miahmouse's Avatar
Default Re: Distributor Help!!!!! (ImportRacr05)
not 100% but I think the plug is different...
coil go bad? the coils should swap
Old Nov 9, 2006 | 06:25 AM
I am not entire sure what the problem is, its stranded about 20 minutes from my house. It bogged REAL bad, then shut off. Wouldnt start again. Opened the hood, the #4 plug wire had popped off the distributor. Put it back on, still nothing.
Old Nov 9, 2006 | 08:14 AM
deryck324's Avatar
well it kinda fits but not realy , the dizzy hits the v-tec silinoid , my friend has gotten it to work before but only one bolt fits . i recemend just going to for sale thred and try to find one
Old Nov 9, 2006 | 08:23 AM
I dont have time for that, my car is stranded.
Old Nov 9, 2006 | 09:12 AM
miahmouse's Avatar
Default Re: (ImportRacr05)
If one of your wires popped off it very well may have screwed up the coil. I've removed one of the plug wires while the engine was running (sounded like it was missing) car died and took the coil along with it... test and probably replace coil...
Old Nov 9, 2006 | 09:21 AM
vlc92189's Avatar
im like 99.9% sure that your coil went bad... mine went bad in the biggest rain storm of the year about 15 mins from my house.. sucked. go check your coil out and find a autozone nearby and by it.. if it dont worrk take it back. but im sure thats it.
Old Nov 9, 2006 | 09:23 AM
klungemonger's Avatar
And if it is the coil, the LS coil and even one from a D-series will work in the GSR dizzy.
Old Nov 9, 2006 | 08:02 PM
word. I will relay to the shop that my car is at.
Old Nov 10, 2006 | 03:43 AM
Basically only the mounts on the distributor housing is different, you can swap all the internals between dizzies. Like if you wanted to convert an OBD1 GSR to OBD2 and you had an OBD2 LS dizzy laying around you can just pull all the stuff out and stick it into the GSR housing.
rhdins
May 7, 2019 06:37 AM
808DA
Mar 26, 2009 05:24 PM
Blk00EJ8
Apr 28, 2007 01:27 PM
spunky424
Nov 7, 2004 06:17 AM
gsrvx
Jun 6, 2002 11:27 AM
