bad distributor?
Old Mar 25, 2009 | 10:35 PM
808DA's Avatar
Default bad distributor?
my friend removed the spark plug wires from the distributor cap thinking that he needed to remove them to do a volatege drop to check his starter. he then cranked the ignition, now he installs the wires back to the distributor, and the car doesnt want to start now. did he ruin his distributor?
Old Mar 25, 2009 | 11:11 PM
emooheo's Avatar
Default Re: bad distributor?
are the plugs in the right order?
Old Mar 25, 2009 | 11:38 PM
808DA's Avatar
yes, all plug wires are in the correct order.
Old Mar 26, 2009 | 09:49 AM
rice a roni's Avatar
Best thing to do is buy a inline spark tester, connect it between the cap and the spark plug wire then see if it has spark.
Old Mar 26, 2009 | 10:20 AM
ruffrhyder's Avatar
Sounds like your buddy owes you a new ignition coil or module.
Old Mar 26, 2009 | 05:24 PM
808DA's Avatar
found the problem, bad ignition coil. thanks for all the help
gizmo jdm
Nov 14, 2011 04:29 AM
halocore
Jan 8, 2010 04:20 PM
crxion91
Jan 19, 2008 12:35 PM
88 honda prelude
Jul 28, 2007 05:50 AM
CptCorN
Jan 17, 2005 06:33 AM
