ELD prob?
Old Nov 7, 2006 | 04:00 AM
jdmeg9's Avatar
Default ELD prob?
got in my car today to warm it up and it would just crank until i gave it gas and then it started.
then it died..............
ran a scan on it later and it is throwing code 1, 6, 20, and 22 i think. i can figure out all the other problems except the eld someone said for me to fix code 1 which is the o2 sensor and see if that fixes the eld code is that true?
Old Nov 7, 2006 | 05:23 AM
pdiggitydogg's Avatar
check the alternator fuse under the dash
Old Nov 7, 2006 | 06:11 AM
jdmeg9's Avatar
Default Re: (pdiggitydogg)
there isn't a fuse under the dash labeled as alternator or in engine bay
Modified by jdmeg9 at 3:32 PM 11/7/2006
Old Nov 7, 2006 | 06:43 AM
JDM_teh_WIN!!'s Avatar
Default Re: (jdmeg9)
To test the ELD you need to hook a volt meter to a few different connections. If all else fails you need to replace the main fuse box.
Old Nov 7, 2006 | 06:54 AM
EE_Chris's Avatar
Default Re: (JDM_teh_WIN!!)
There is a fuse for the alternator. You need a Helms and multimeter to troubleshoot this problem.
Old Nov 7, 2006 | 07:19 AM
jdmeg9's Avatar
Default Re: (EE_Chris)
i reset the light after fixing all the problems except eld started the car and it ran fine. drove it for 20 miles no hesitation came home and ran a scan on it again and it didn't show anything. i never had a check light before either and i still don't have one but eld isnt coming up on a scan anymore.
Old Nov 7, 2006 | 08:40 AM
fyi: a bad alternator fuse will throw that series of codes all at once
Old Nov 7, 2006 | 08:41 AM
POE's Avatar
POE
bad relay?
Old Nov 7, 2006 | 08:45 AM
Default Re: (POE)
Yes also try resetting the ECU.
Old Nov 7, 2006 | 04:10 PM
jdmeg9's Avatar
a bad alternator fuse will throw those codes? i still don't have an alternator fuse
Old Nov 7, 2006 | 04:21 PM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 &raquo;</TD></TR><TR><TD CLASS="quote">i still don't have an alternator fuse </TD></TR></TABLE>
Maybe that's it - you're missing the fuse altogether because from the factory, there was one.
Old Nov 7, 2006 | 04:32 PM
jdmeg9's Avatar
Old Nov 7, 2006 | 05:02 PM
under the dash chief
Old Nov 7, 2006 | 05:10 PM
EE_Chris's Avatar
Just take a picture of the under-dash fuse layout diagram.
Old Nov 7, 2006 | 06:43 PM
jdmeg9's Avatar
if it is the acg fuse which i guess it would have to be unless it is labeled headlight or something stupid what do i do if it isn't blown? the car runs and it only kicked the code once. just put a newer fuse in it?
Modified by jdmeg9 at 3:59 AM 11/8/2006
Old Nov 8, 2006 | 05:01 AM
EE_Chris's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 &raquo;</TD></TR><TR><TD CLASS="quote">the car runs and it only kicked the code once. just put a newer fuse in it?</TD></TR></TABLE>
You can try a newer fuse if you wish, but I wouldn't put any money on it. It sounds like there isn't a problem now??
Old Nov 8, 2006 | 02:15 PM
jdmeg9's Avatar
well i mean there is obviously a problem somewhere maybe the alternator going out?
b18c-gsr
Jan 30, 2025 04:40 AM
spooned out
Sep 24, 2006 09:12 PM
ZUL8R
Oct 7, 2005 03:08 PM
99ek9
Oct 27, 2004 10:26 AM
cjames235
Dec 27, 2003 06:17 AM
