ELD prob?
ELD prob?
got in my car today to warm it up and it would just crank until i gave it gas and then it started.
then it died..............
ran a scan on it later and it is throwing code 1, 6, 20, and 22 i think. i can figure out all the other problems except the eld someone said for me to fix code 1 which is the o2 sensor and see if that fixes the eld code is that true?
Re: (pdiggitydogg)
there isn't a fuse under the dash labeled as alternator or in engine bay
Modified by jdmeg9 at 3:32 PM 11/7/2006
Re: (EE_Chris)
i reset the light after fixing all the problems except eld started the car and it ran fine. drove it for 20 miles no hesitation came home and ran a scan on it again and it didn't show anything. i never had a check light before either and i still don't have one but eld isnt coming up on a scan anymore.
Re: (jdmeg9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 »</TD></TR><TR><TD CLASS="quote">i still don't have an alternator fuse </TD></TR></TABLE>
Maybe that's it - you're missing the fuse altogether because from the factory, there was one.
Re: (EE_Chris)
if it is the acg fuse which i guess it would have to be unless it is labeled headlight or something stupid what do i do if it isn't blown? the car runs and it only kicked the code once. just put a newer fuse in it?
Modified by jdmeg9 at 3:59 AM 11/8/2006
Re: (jdmeg9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 »</TD></TR><TR><TD CLASS="quote">the car runs and it only kicked the code once. just put a newer fuse in it?</TD></TR></TABLE>
You can try a newer fuse if you wish, but I wouldn't put any money on it. It sounds like there isn't a problem now??
b18c-gsr
01-21-2014 11:25 AM
