Piston ring question....
Old Nov 2, 2006 | 07:09 AM
chicchocrider's Avatar
Default Piston ring question....
I've search..... and learn some stuff but i still got 1 question
The stock one are 81.0 for all b-series
and there is a lot of search result about Oversize piston ring......81.5 i think
Did it came stock on some engen or it's al been replace form some reason...
I'm asking because i'll change my ring on my 98 spec JDM engen this month and I want malke sure il'll be getting the wright one....
Thanks...!
Old Nov 2, 2006 | 07:16 AM
BABY NSX's Avatar
Default Re: Piston ring question.... (chicchocrider)
Piston rings are matched to the piston diameter, which of course is matched to the bore diameter. If your installing oversize pistons then you need rings to match. OE size pistons require OE size rings.
Old Nov 2, 2006 | 07:33 AM
totsie7944's Avatar
if you have oem pistons you want oem piston rings...
Old Nov 2, 2006 | 07:43 AM
sackdz's Avatar
OEM oversize is 81.25mm
Old Nov 2, 2006 | 09:11 AM
92TypeR's Avatar
FSAE
Unless you bore the cylinders out to 81.5, use 81mm.
If you have a machine shop use an aggressive hone, measure ring gap and make adjustments as necessary.
If all of this sounds complicated, pay someone.
Old Nov 2, 2006 | 09:34 AM
USDM and JDM piston ring are exacltly the same? if not... i guess ebay or h-t is the best place to get some in canada?
and ... OEM oversize are 81.25.... in what case do you end up with those.... to me OEM oversize sound ironic....
Old Nov 2, 2006 | 02:08 PM
DC2fanboy's Avatar
Default Re: (chicchocrider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chicchocrider &raquo;</TD></TR><TR><TD CLASS="quote">USDM and JDM piston ring are exacltly the same?</TD></TR></TABLE>
yes.
The oversize is for bottom end rebuilds where the bore is increased slightly (and to be used with the "rebuild" 81.25 pistons.
Old Nov 3, 2006 | 10:30 AM
Default Re: (DC2fanboy)
good..... now i got it!
thanks
snap334
May 5, 2018 11:11 AM
turbo boost
Oct 27, 2014 11:09 PM
quik1
Jun 19, 2004 06:33 PM
BioXide02
Feb 22, 2004 12:29 PM
Cyber ITR
May 18, 2002 02:28 AM
