Piston ring question! Quick response would be nice..
Old Feb 20, 2004 | 07:30 PM
BioXide02's Avatar
Default Piston ring question! Quick response would be nice..
Okay I have a d16y8 and I need to get some new rings for my pistons.. I am using SRP 75mm forged pistons, 9:1 compression.. My question is can I just go to the honda-dealership and buy some OEM d16y8 piston rings? And if so do I just get the standard or the (OS 0.25) or (OS 0.50)? Or would I be better off buying the rings of JE/SRP instead?? Thanks!
Old Feb 20, 2004 | 11:09 PM
BioXide02's Avatar
Default Re: Piston ring question! Quick response would be nice.. (BioXide02)
Old Feb 20, 2004 | 11:50 PM
TravSi's Avatar
get the rings with the pistons....
Old Feb 21, 2004 | 10:37 AM
BioXide02's Avatar
Default Re: Piston ring question! Quick response would be nice.. (TravSi)
up..
Old Feb 21, 2004 | 11:19 AM
omahaturbocivic's Avatar
It depends on the piston manufacturer, not all aftermarket use the same thickness rings and Im am pretty sure je/srp use their own size so you have to use their rings. If they used the same thickness rings as oem then you could use oem rings.
Old Feb 21, 2004 | 11:53 AM
BioXide02's Avatar
Default Re: Piston ring question! Quick response would be nice.. (omahaturbocivic)
Can anyone confirm if srp rings are the same thickness as OEM?
Old Feb 21, 2004 | 03:12 PM
GPNY's Avatar
Yes use oem rings. They are the same thickness as stock srp pistons (ie not custom ordered) the thickness is 1.0,1.2,2.8mm
Do check the gap, but usually oem rings dont need to be filed
Use 75mm rings if you have 75mm pistons.
Old Feb 21, 2004 | 04:13 PM
BioXide02's Avatar
Default Re: Piston ring question! Quick response would be nice.. (Gpelsise)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gpelsise &raquo;</TD></TR><TR><TD CLASS="quote">Yes use oem rings. They are the same thickness as stock srp pistons (ie not custom ordered) the thickness is 1.0,1.2,2.8mm
Use 75mm rings if you have 75mm pistons. </TD></TR></TABLE>
Thanks for the info
Old Feb 22, 2004 | 11:03 AM
BioXide02's Avatar
Okay so I was looking online to buy some OEM piston rings. http://www.hondaautomotivepart...ISTON And it says ring set.. but does that mean just for one piston... or for all four??
Old Feb 22, 2004 | 12:29 PM
GPNY's Avatar
Each...
That's pretty expensive...
Call up wiseco and say that you have a set of their customs pistons that 2953XC ring set. You might be able to get athem for $80 for the set... (Engine builder price) Just be nice to the guy...
turbo boost
Oct 27, 2014 11:09 PM
b20beast83
Apr 22, 2010 09:32 AM
Clerique
Oct 4, 2008 05:14 PM
quik1
Jun 19, 2004 06:33 PM
KENetics1
Apr 7, 2003 11:43 AM
