Throwing A Code 20 Need Help
Old Oct 21, 2006 | 02:14 PM
Sportyballade's Avatar
Default Throwing A Code 20 Need Help
I'm throwing a code 20. My lights and guages are going crazy. Need help. How can i fix this code?
Old Oct 22, 2006 | 12:06 PM
jdeemseerx's Avatar
Default Re: Throwing A Code 20 Need Help (Sportyballade)
check your alternator output with a multimeter come back with the results
Old Oct 26, 2006 | 09:44 AM
Default Re: Throwing A Code 20 Need Help (jdeemseerx)
Would a bad alternator make my car behave like this?
Old Oct 26, 2006 | 10:16 AM
fmrprojects's Avatar
turn the car on and pull the bat neg off. if the car dies then the alternator is bad.
Old Oct 26, 2006 | 12:55 PM
Default Re: Throwing A Code 20 Need Help (fmrprojects)
Will a bad alternator cause the car to throw a code 20?
Old Oct 26, 2006 | 09:04 PM
jdeemseerx's Avatar
yes it can, and it can also cause the symptoms your having with the gauges..also make sure all of your grounds are making good contact and the ground wires are in good condition
Old Oct 27, 2006 | 12:53 AM
fasthatchb18c1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sportyballade &raquo;</TD></TR><TR><TD CLASS="quote">Will a bad alternator cause the car to throw a code 20?</TD></TR></TABLE>
It could and high resistance in your wires could as well. Check the voltage at your alternator then at your battery. If there is more that a .5v drop its high resistance and you can go from there. If your alternator reads below 13v with no load(idling with all accessory's off) its your alternator.
Old Oct 27, 2006 | 03:54 AM
Mr Hammond's Avatar
a/k/a Jomo
Isn't code 20 for an ELD? May want to start there. Under hood fuse box.
Old Oct 27, 2006 | 05:05 AM
EE_Chris's Avatar
Is this a stock car? If not, what's the setup? Do you have a Helms? Do you have a multi-meter?
killakalipoph
Aug 20, 2011 06:20 PM
Dubs13
Aug 31, 2009 06:23 PM
mugenhatch92
Aug 31, 2004 06:51 PM
CimorelliCRX
15
Feb 27, 2003 11:57 AM
