Stiff Heat/Cold Control Slider...
Is there any cheap/easy trick or fix when the slider becomes really stiff?
It's a bit tough to move the slider from cold to hot nowadays....
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhoenixDownVII »</TD></TR><TR><TD CLASS="quote">Is there any cheap/easy trick or fix when the slider becomes really stiff?
Thanks</TD></TR></TABLE>
I'M having this problem aswell, the only thing i can think of is some silicone spray on the cable or something, i've broken 2 climate control sliders because of this.
Thanks</TD></TR></TABLE>I'M having this problem aswell, the only thing i can think of is some silicone spray on the cable or something, i've broken 2 climate control sliders because of this.
How'd you break them? Just got too stiff over time?
What's behind it? Ever take a look? I haven't pulled a DC dash apart, this is my first 94+ integra, owned 3 90-93 model's before this....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by orangebarius »</TD></TR><TR><TD CLASS="quote">i used silicone spray on mine and it worked very well.</TD></TR></TABLE>
Where did you spray?
As Patrick said? Up and behind removing the deck & ashtray to get to it? Right behind the **** you push or where it leads to towards the front?
I guess I really should just be getting under/in there
Thanks for the headsup guys!
if you look under the right hand side of your dash you can see the cable, just spray some silicone spray on the cable and see if it loosens up. it maybe necessary to remove the climate control and spray both ends of the cable. but yes it is binding up, like i said i'm having this problem too and i know mine is binding up.
dE.fUsEd
Aug 28, 2013 06:12 AM
navin
Dec 16, 2007 10:04 PM
Attoir
Dec 18, 2003 03:05 PM
