climate control problem
Old Jun 9, 2002 | 06:43 PM
eric712's Avatar
Default climate control problem
I took off the climate control and put it back on - now when it is all the way at the coldest level, w/o the A/C on, it still spits out warm air...still gets really hot when I move the control all the way to the right, but is there something that I forgot to do when putting the climate control on that is making the air come out warm when the dial is pushed all the way tot he left?
this is a 94 integra
Thanks
Old Jun 9, 2002 | 06:54 PM
iH8RICERZ's Avatar
Default Re: climate control problem (eric712)
your going to have to take it off again... you have to pull the switch all the way on cold or was it hot..then hook up the cable. If you follow where the cable goes... you'll see a lever underneath the passenger side dash where the cable pulls and pushes the lever. Thats where it controls the cold and warm air. Depending on which way you turn your switch at on the climate control.. you need to do the same w/ the lever on the bottom.
Old Jun 9, 2002 | 07:04 PM
Erik_Pb_Foot's Avatar
New User
Default Re: climate control problem (BustAhNutZ101)
couldn't have said it better myself... but... to save some time, check down under the dash where the cable goes to and see if maybe you did in fact connect the cable to the climate control panel but maybe just forgot to hook it up underneath. good luck
-erik
Old Jun 9, 2002 | 07:20 PM
eric712's Avatar
Is there a way of taking it off w/o taking out the radio?
Eric
1HONDA4U2NV
Oct 13, 2009 12:25 PM
1991hb
Aug 12, 2009 02:16 PM
DOHCter VTEC
Jan 21, 2008 09:03 PM
92BlackSi
Nov 9, 2004 04:52 AM
sjteg
May 11, 2003 04:17 PM
