yet an other idle problem
Old Oct 7, 2006 | 03:37 PM
coronadrinker's Avatar
Default yet an other idle problem
cleaned the IACV, and the FITV but i still have a f'ed up idle. When cold it idles at 2k , when worm it will sometimes idle at 2 and some times jump from 1k to 2.5k, tried searching... need help, scared of running lean
P.S. when i cleaned out the FITV i screwed it all the way back in, should i have not done that?
Old Oct 7, 2006 | 03:52 PM
Lookattheac's Avatar
i had the same problem in my gsr. you might need to replace the IACV cuz the motor inside died i replaced mine and that took care of it
Old Oct 8, 2006 | 11:09 AM
Default Re: (Lookattheac)
i'll try that today... any other ideas?
Old Oct 8, 2006 | 05:08 PM
Default Re: (coronadrinker)
so.... i replaced my TB with a spare, it had the TPS and MAP on it almong with the FITV, now my idle is all good, not sure if it was one of the sensors or how i had the FITV set up, but its good now
Old Oct 8, 2006 | 06:09 PM
93Ls-tegra's Avatar
Default Re: yet an other idle problem (coronadrinker)
tune your car.....
Old Oct 8, 2006 | 06:48 PM
Default Re: yet an other idle problem (93Ls-tegra)
my car is tuned... on crome...and the problem is gone
Old Oct 8, 2006 | 07:55 PM
db8vtec's Avatar
what year is ur gsr...? i just got my engine rebuilt and teh first time i started.. it was ffine until i have to redo the head bcuz machine shop mess up... i got everything back together and now its idle crazy.... first start... idle at 200rpm.. tats low.. 50sec. later.. it idle higher.. then it start to idle up and down.....? i did clean out the valve, but it shouldnt be a sudden change that quick> can it?
i have a 96 gsr.....i found out that 94 is a lil diff. then my 96 ....
Old Oct 8, 2006 | 09:17 PM
Default Re: yet an other idle problem (db8vtec)
i have a ls-v, not sure how fast a sensor can go bad but it sound similar to what was happening to me
Old Oct 9, 2006 | 05:11 AM
Duane_in_Japan's Avatar
search for my name and idle fluctuation. May be in different section, search on all of HT.
mikeunreal2
Mar 29, 2006 09:27 PM
kihun_cha
20
Sep 17, 2004 03:18 PM
TheIntegraGuy
Jan 22, 2004 06:48 PM
diLUDEd
Aug 22, 2002 10:08 PM
