tryin to install univeral tachometer
I don't know what color your wires are, but my autometer has GREEN RED BLACK WHITE.
Green: Connects to the bold blue wire on your dist.
White: Dimmer or you can wire it straight into your lights.
Red: Key on Power Source(I forget which fuse I used but it was much easier this way. Drivers Side Dash Fusebox...someone else may know which fuse exactly)
Black: Ground
Make sure you are doing this correctly. Don't just shave-twist-and electrical tape the connections together. Soder(bad spelling yes) them, then tape it up properly or else you'll most likely get inaccurate readings.
Black: Ground
sorry maybe a bit slow or dont have enough practice but..
dist.. is distributor?
how to wire it to my lights? which lights? just cut?
key on power source.. how do u exactly put it to the fuse?
and black ground to the battery?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steven Poljak »</TD></TR><TR><TD CLASS="quote">sorry maybe a bit slow or dont have enough practice but..
and black ground to the battery?</TD></TR></TABLE>
Dist is the distributor correct- Get a nice set of strippers or scotch clamps and tee in - If you strip, make sure to solder dont half *** it tape everything up properly
lights- check out a manual for which wire to cut- usualy near light switch im assuming
for 12volt the easiest would be finding a fuse and just pigybacking off it
ground- dont groudn to battery ground to a metal point on the vehicle
Id recomend having a freind do it for you with him showing you how
wow, yes its blue and if you dont know where the shock tower is there is a problem, its the big hump on the side of the engine bay where the shock attaches too...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B1_4DR »</TD></TR><TR><TD CLASS="quote">I don't know what color your wires are, but my autometer has GREEN RED BLACK WHITE.
Black: Ground
Make sure you are doing this correctly. Don't just shave-twist-and electrical tape the connections together. Soder(bad spelling yes) them, then tape it up properly or else you'll most likely get inaccurate readings.</TD></TR></TABLE>
Black: Ground
what he said
imptricer
13
Nov 22, 2012 07:47 PM
Rev-Olution
11
Jun 11, 2004 07:30 PM
