clock rewiring helpd
Old Jun 17, 2003 | 03:38 PM
JiGzAcura's Avatar
Default clock rewiring helpd
i recently installed a new radio in my integra.. i didnt realize that i disconnected the clock and now im not sure how to rewire it. the 4 wires that go to the clock is a red/black, yellow, black, and white/blue. Down by the radio i see only the red/black wire and 3 identical white/blue wires soldered together. Can someone please help me rewire?
Old Jun 17, 2003 | 03:53 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: clock rewiring helpd (JiGzAcura)
Black is ground, yellow is the main power supply thru the ignition on switch, coming thru fuse no. 15 (10A) from under the dash. The red/black wire is the lights on signal (dimming circuit), coming from the No. 19 10A fuse (parking lights, taillights, etc.) under the dash. The white/blue wire is the constant power that keeps the clock's time, coming from the No. 32 7.5A fuse under the hood (the fuse for the clock, stereo, ECU, etc. constant power).
Old Jun 17, 2003 | 06:19 PM
JiGzAcura's Avatar
The wires that are coming from the clock should go to which wires on the radio harness?
Old Jun 17, 2003 | 07:12 PM
Community Builder
Default Re: (JiGzAcura)
There is a white/blue wire coming from the ECU fuse (no. 32, 7.5A) under the hood, it goes to both the clock and the radio. The red/black wire coming from the no. 19 fuse (10A) under the dash goes to both the clock and the radio. The radio is wired to come on in the ACC position, the clock comes on in the IG1 position, so those wires for main power are different. For the clock, there is a black/yellow wire coming from the IG1 position on the ignition switch, going to no. 15 (10A) fuse under the dash, and then a yellow wire going to the clock. The black wire from the clock just connects to any ground point, there are a couple of bolts used as grounds back behind the radio.
How did you go about disconnecting the clock in the first place? Did you cut some wires that you shouldn't have?
Old Jun 18, 2003 | 12:19 PM
dip-set's Avatar
Default Re: (PatrickGSR94)
lovely brake down...
Busterfla
Nov 16, 2014 11:22 AM
Hatesmakingaccs
15
Apr 26, 2014 08:24 PM
89civicsiowner
Audio / Security / Video
Jun 5, 2009 09:53 AM
lrcrx90
16
Jul 28, 2007 07:35 AM
Steven.
Oct 4, 2006 05:53 PM
