tryin to install univeral tachometer
Old 10-04-2006, 12:13 PM
Steven.'s Avatar
Default tryin to install univeral tachometer
it has 4 wires, its a timex one.
it comes with crappy install instructions.
anyone?
Old 10-04-2006, 12:21 PM
B18B1_4DR's Avatar
Default Re: tryin to install univeral tachometer (Steven Poljak)
I don't know what color your wires are, but my autometer has GREEN RED BLACK WHITE.
Green: Connects to the bold blue wire on your dist.
White: Dimmer or you can wire it straight into your lights.
Red: Key on Power Source(I forget which fuse I used but it was much easier this way. Drivers Side Dash Fusebox...someone else may know which fuse exactly)
Black: Ground
Make sure you are doing this correctly. Don't just shave-twist-and electrical tape the connections together. Soder(bad spelling yes) them, then tape it up properly or else you'll most likely get inaccurate readings.
Old 10-04-2006, 03:48 PM
Steven.'s Avatar
sorry maybe a bit slow or dont have enough practice but..
dist.. is distributor?
how to wire it to my lights? which lights? just cut?
key on power source.. how do u exactly put it to the fuse?
and black ground to the battery?
Old 10-04-2006, 03:53 PM
vestalfootball72
Guest
Posts: n/a
Default Re: (Steven Poljak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steven Poljak &raquo;</TD></TR><TR><TD CLASS="quote">sorry maybe a bit slow or dont have enough practice but..
and black ground to the battery?</TD></TR></TABLE>
Dist is the distributor correct- Get a nice set of strippers or scotch clamps and tee in - If you strip, make sure to solder dont half *** it tape everything up properly
lights- check out a manual for which wire to cut- usualy near light switch im assuming
for 12volt the easiest would be finding a fuse and just pigybacking off it
ground- dont groudn to battery ground to a metal point on the vehicle
Id recomend having a freind do it for you with him showing you how
Old 10-04-2006, 04:15 PM
Soccerking3000's Avatar
Default Re: (vestalfootball72)
or instead of hacking up your dizzy wires you just take the signal wire that behind the driver side shock tower
Old 10-04-2006, 05:21 PM
Steven.'s Avatar
how do u spot the signal wire, is it blue? where exactly is the shock tower
Old 10-04-2006, 05:23 PM
wow, yes its blue and if you dont know where the shock tower is there is a problem, its the big hump on the side of the engine bay where the shock attaches too...
Old 10-04-2006, 05:50 PM
lthao61's Avatar
Default Re: tryin to install univeral tachometer (B18B1_4DR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18B1_4DR &raquo;</TD></TR><TR><TD CLASS="quote">I don't know what color your wires are, but my autometer has GREEN RED BLACK WHITE.
Black: Ground
Make sure you are doing this correctly. Don't just shave-twist-and electrical tape the connections together. Soder(bad spelling yes) them, then tape it up properly or else you'll most likely get inaccurate readings.</TD></TR></TABLE>
what he said
Old 10-04-2006, 05:53 PM
Slamaccord's Avatar
Default Re: (Soccerking3000)
https://honda-tech.com/zerothread?id=949918 \
There you go.
mdog244
15
01-02-2018 05:25 PM
imptricer
13
11-22-2012 07:47 PM
Rev-Olution
11
06-11-2004 07:30 PM
JiGzAcura
06-18-2003 12:19 PM
R-1303
05-30-2002 08:27 PM
Quick Reply: tryin to install univeral tachometer
