wastegate spring swap
will a stock .6 bar spring from a 44mm tial wastegate be swapable w/ a 12lbs (not sure what rate of bar) spring from a 38mm tial wastegate? Just curious cause' my wife needs a lower rate spring (mine) and mine doesn't matter but if she can use mine then i'll use hers w/ a Greddy profec B... TIA
Shane
Shane
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy »</TD></TR><TR><TD CLASS="quote">from what i've been told the highes you can go on a spring is double the amount of boost the spring is made for. EX. 7 PSI spring is good only to 14 PSI</TD></TR></TABLE>
?? I'm not sure I understand what you're saying... I'm asking if my spring will fit into her wastegate..
That sounds sooo dirty....LOL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">all tial wastegate uses the same springs. but the spring rate may diff by 1-3psi. go to tials website to see what it will give out</TD></TR></TABLE>
Yeah I went to their site when I was at work (shhhh don't tell anyone LOL) and their site wasn't working... I'll try again later...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbadboy »</TD></TR><TR><TD CLASS="quote">lol i thought u were asking how much boost you could get out of the .6 bar spring. if it doesn't fit just use some KY haha</TD></TR></TABLE>
LOL hell yeah it'll fit for sure then... hahahaha
JDM turbo DC
Jan 29, 2006 06:20 PM
PGT Driver
Apr 13, 2004 07:54 PM
