Question Regarding D16Z6 2 Versions of Engine Mounts
Old Sep 19, 2006 | 01:47 PM
LowTEC-Derbo's Avatar
Default Question Regarding D16Z6 2 Versions of Engine Mounts
I am well aware that the 94-95 engine mounts are different from mine, which is a 1993 civic ex coupe.
I was curious if anyone knew the major differences between the driver side mount because I am looking to ES engine mounts but not sure if they will work w/ my older Dseries mount.
Has anyone use ES inserts on their 92si or 93 si or 93 ex coupe? Or even tried to use the NRG Engine Damper since I have one laying around and I had no luck.
Old Sep 19, 2006 | 05:35 PM
Default Re: Question Regarding D16Z6 2 Versions of Engine Mounts (crazyxzer0)
Old Sep 19, 2006 | 05:39 PM
SOHCejcivic's Avatar
i'd like to know too. i think a wad of snot would do better than my mounts right now
Old Sep 19, 2006 | 05:40 PM
Everyones Hero's Avatar
The 92-95 civics all use the same mounts, don't they?
Old Sep 19, 2006 | 06:16 PM
Default Re: Question Regarding D16Z6 2 Versions of Engine Mounts (Everyones Hero)
not really..
The driver side mount has 2 different mount part numbers on the Honda Catalog.
There is 10, 11 and 9
10 is the 94-95 and 11 is the 92-93... so i'm curious if the upper portion (chassis) works cause majority of people who use the es inserts I know have the 94-95. I don't know what 9 is...
Old Sep 19, 2006 | 06:47 PM
NJcoupe's Avatar
One is the standard 92-93 Civic mount, and the other 94-95 Civic Uses the Integra style mount.
Old Sep 19, 2006 | 07:19 PM
Default Re: Question Regarding D16Z6 2 Versions of Engine Mounts (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. &raquo;</TD></TR><TR><TD CLASS="quote">One is the standard 92-93 Civic mount, and the other 94-95 Civic Uses the Integra style mount.</TD></TR></TABLE>
sweet!! does anyone know if the es inserts fit the 92-93 civic mount?
Old Sep 19, 2006 | 07:51 PM
B and B's Avatar
Loved
Community Favorite
I cleaned and filled my stock ones with urethane from a caulk tube. Smooth the surfaces while wet. Took days to cure but they're sweet now. 6 bucks.
Old Sep 19, 2006 | 08:58 PM
Default Re: Question Regarding D16Z6 2 Versions of Engine Mounts (B and B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B and B &raquo;</TD></TR><TR><TD CLASS="quote">I cleaned and filled my stock ones with urethane from a caulk tube. Smooth the surfaces while wet. Took days to cure but they're sweet now. 6 bucks.</TD></TR></TABLE>
daily driver ftL
Old Sep 19, 2006 | 10:16 PM
Luserkid's Avatar
I did that and they held up alright for a while. A couple trips to the track with slicks showed a different story and its time for solids.
The ES inserts dont even go to the upper driver mount. It goes to the rear tranny mount, AC mount and front tranny torque mount. Those mounts are all the same.
Old Sep 20, 2006 | 09:59 AM
Default Re: Question Regarding D16Z6 2 Versions of Engine Mounts (Luserkid)
sweet. time to purchase a set then. I was under the impression they were motor mounts..... not torque mounts that were putting inserts in.
Old Sep 20, 2006 | 03:50 PM
As you can see, there is 9 and 8...
I run 8 on the 92-93.. I can't run a NRG damper
fuzzysig
Acura TSX
Jun 6, 2017 09:31 AM
Turbo-charged
Mar 11, 2008 04:24 PM
Poroshok
Jul 16, 2007 07:12 PM
mingchi69
Feb 20, 2004 08:08 PM
