Question Regarding D16Z6 2 Versions of Engine Mounts
I am well aware that the 94-95 engine mounts are different from mine, which is a 1993 civic ex coupe.
I was curious if anyone knew the major differences between the driver side mount because I am looking to ES engine mounts but not sure if they will work w/ my older Dseries mount.
Has anyone use ES inserts on their 92si or 93 si or 93 ex coupe? Or even tried to use the NRG Engine Damper since I have one laying around and I had no luck.
Re: Question Regarding D16Z6 2 Versions of Engine Mounts (crazyxzer0)
i'd like to know too. i think a wad of snot would do better than my mounts right now
Re: Question Regarding D16Z6 2 Versions of Engine Mounts (Everyones Hero)
not really..
The driver side mount has 2 different mount part numbers on the Honda Catalog.
There is 10, 11 and 9
10 is the 94-95 and 11 is the 92-93... so i'm curious if the upper portion (chassis) works cause majority of people who use the es inserts I know have the 94-95. I don't know what 9 is...
Re: Question Regarding D16Z6 2 Versions of Engine Mounts (dxcoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dxcoupe. »</TD></TR><TR><TD CLASS="quote">One is the standard 92-93 Civic mount, and the other 94-95 Civic Uses the Integra style mount.</TD></TR></TABLE>
sweet!! does anyone know if the es inserts fit the 92-93 civic mount?
Re: Question Regarding D16Z6 2 Versions of Engine Mounts (B and B)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B and B »</TD></TR><TR><TD CLASS="quote">I cleaned and filled my stock ones with urethane from a caulk tube. Smooth the surfaces while wet. Took days to cure but they're sweet now. 6 bucks.</TD></TR></TABLE>
daily driver ftL
daily driver ftL
I did that and they held up alright for a while. A couple trips to the track with slicks showed a different story and its time for solids.
The ES inserts dont even go to the upper driver mount. It goes to the rear tranny mount, AC mount and front tranny torque mount. Those mounts are all the same.
Re: Question Regarding D16Z6 2 Versions of Engine Mounts (Luserkid)
sweet. time to purchase a set then. I was under the impression they were motor mounts..... not torque mounts that were putting inserts in.
As you can see, there is 9 and 8...
I run 8 on the 92-93.. I can't run a NRG damper
Turbo-charged
03-11-2008 04:24 PM
