Boostin the ls
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91turboteg »</TD></TR><TR><TD CLASS="quote">
ps; tried searching
you are the failzor at searching
https://honda-tech.com/zerothread?id=1641037
https://honda-tech.com/zerothread?id=1517870
https://honda-tech.com/zerothread?id=819653
https://honda-tech.com/zerothread?id=269853
ps; tried searching
check this thread out
https://honda-tech.com/zerothread?id=1323059 263 pages of replies you must have not searched for this
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91turboteg »</TD></TR><TR><TD CLASS="quote">Sorry should have made it more clear how much HP can the block handle
i'm seein alot around 250 can i go higher</TD></TR></TABLE>
do you have stock internals? if so then 250 would probably be about what you can get out of it. with a good tune. as soon as you start building the motor you can make more power.
Yes I have stock internals.
btw. why don't people understand that
lbs of boost doesn't mean **** unless you describe what size turbo you have
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ruben19 »</TD></TR><TR><TD CLASS="quote">it wont last very long.
you must upgrade your internals if you are running 16lbs boost.
watch it blow soon</TD></TR></TABLE>
agreed, 16 sounds rather high, most people with boosted applications i have seen running stock internals run 8 psi safe and not really ne thing more than 12. 16lbs of boost on a cold day when the air density is higher just watch......
Oh really?
16-17lbs on a 57trim .63turbine t3/t04e DAILY DRIVEN FOR 2 YEARS!
I tuned it and it runs great. I now have a built engine, but it had great compression till the end. 300whp seems to be a safe limit if you have a healthy motor. Get a conseravtive tune and you'll be fine
Ruben...you're an idiot
Oh really?
cars lasted a long time buddy. big sc61 on 16-17 pounds. daily driven. making 300 whp too. someone needs to research before they run their mouth.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy »</TD></TR><TR><TD CLASS="quote">Ruben...you're an idiot
So you say 300 whp is safe?
I rebuilt my engine last year, have less than 5000 miles on it
i just want to be sure.
thanks for all the help so far guys
