Odd surging problem while under partial throttle
Old Aug 6, 2006 | 06:11 AM
ham's Avatar
ham
Default Odd surging problem while under partial throttle
93 CX idles fine, but when you give it the slightest amount of throttle, it starts surging like a 2 step or launch control! Between 1 and 2k rpm
Its very annoying on the highway when youre cruising under very little load and it starts making the car jump.
it did it with the stock motor and ECU, then did it with a turbo d series...and STILL does it with a fully built B series turbo setup. Differenct ECU, different everything! what could it be?
Modified by ham at 4:59 PM 3/17/2007
Old Aug 6, 2006 | 06:19 AM
Syndacate's Avatar
Vacuum leak.
Old Aug 6, 2006 | 06:21 AM
ham's Avatar
ham
Default Re: Odd surging problem while under partial throttle (ham)
no more codes
Modified by ham at 4:20 PM 3/15/2007
Old Aug 6, 2006 | 06:32 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">i usually dont have problems reading codes... but this is odd.
Turn the key on with the paperclip in and I get:
Long blink, pause, long blink, pause, long blink long blink, pause. wtf!?
Well it sounds like ur throwing a 10 code, which is IAT sensor..that can cause a surging idle as well, might wanna change that and see where you're at. Or post a video of the CEL blinking to verify with other H/T members that it's a 10 code.
Old Aug 6, 2006 | 07:50 AM
ham's Avatar
ham
Modified by ham at 12:17 PM 8/6/2006
Old Aug 6, 2006 | 08:08 AM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ham &raquo;</TD></TR><TR><TD CLASS="quote">i &lt;3 photobucket. i resized the file to be tiny, no need for high quality for a CEL video
http://smg.photobucket.com/alb...L.flv
^ it does that then repeats</TD></TR></TABLE>
not working
Old Aug 6, 2006 | 08:17 AM
ham's Avatar
ham
Default Re: Odd surging problem while under partial throttle (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">
not working</TD></TR></TABLE>
i forgot to make it public... try again now if it doesnt show right up, it will be the first preview on the left.
Modified by ham at 12:51 PM 8/6/2006
Old Aug 6, 2006 | 01:47 PM
ham's Avatar
ham
bump?
Old Aug 6, 2006 | 01:56 PM
Lewy. Dee Ayy's Avatar
open photobucket..ftw
Old Aug 6, 2006 | 02:29 PM
ham's Avatar
ham
Default Re: Odd surging problem while under partial throttle (WhiteOut)
Modified by ham at 4:21 PM 3/15/2007
Old Mar 15, 2007 | 12:21 PM
ham's Avatar
ham
bump..... new fully built b series motor is in, and new ECU... STILL DOES IT
WTF!!!???!!
and no codes!
Old Mar 16, 2007 | 05:24 PM
ham's Avatar
ham
bumpppppppp
Old Mar 17, 2007 | 12:58 PM
ham's Avatar
ham
bump
Old Mar 26, 2007 | 03:47 AM
ham's Avatar
ham
i switched over to crome instead of uberdata, and it went away.
TerrenceDinesen
Jan 25, 2012 01:06 PM
lsjon
Apr 24, 2008 09:12 PM
N2O INTEGRA
Sep 14, 2007 12:03 PM
WAFFLES
Apr 25, 2003 01:42 PM
Jdm_Rice_Monster
Jan 14, 2003 07:34 PM
