Turbo makes loud whirring sound, Brand new?
Old Jun 30, 2006 | 09:31 AM
90LSpimpin's Avatar
Default Turbo makes loud whirring sound, Brand new?
Sup folks, just got done doin a turbo install on my buddy's F22. Took the car out for the initial test drive an its makin a "whirring" sound as it revs up and maybe a metal grind (but that could be other thing on the setup). Also, it wouldnt hit boost immediately (unless maybe the guage doesnt have a good vaccuum source) it will be going, at full throttle and all of a sudden i'll have 6psi. The sound definately seems to be coming from the center section of the turbo, it spins fine, its getting oil, and only has minimal normal side-side shaft play. But that noise is scary, almost like turnin on a mini-vac or somethin. Suggestions as to what it might be? I'm taking it apart right now and will post back, and have pics once i do that.
Heres the sweet vid http://media.putfile.com/This-turbo-is-hostingd
Modified by 90LSpimpin at 4:30 PM 6/30/2006
Old Jun 30, 2006 | 09:32 AM
90LSpimpin's Avatar
Default Re: Turbo makes loud whirring sound, Brand new? (90LSpimpin)
Took it apart. The turbine side wheel looks minty, half of the turbine housing looks darker than the other half, maybe heat issues? The compressor housing is fine, but some of the fins on the compressor wheel are slightly flattened at the edges like it was grinding the side of the walls. So that pretty much isolates the problem. Why might this have happened? the car ran for no more than 30 mins last nite, most of which was idle, and the engine and turbo were well primed, i cranked it over for a few mins before actually letting it start. Again turbo is brand new, from ebay, and its not a SS.
Old Jun 30, 2006 | 09:34 AM
beepy's Avatar
You sure it was not a rebuild? Is the Garrett tag red or green?
Old Jun 30, 2006 | 09:35 AM
RogueWorks's Avatar
Default Re: Turbo makes loud whirring sound, Brand new? (beepy)
send it back to the seller for warranty repair
Old Jun 30, 2006 | 09:45 AM
90LSpimpin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beepy &raquo;</TD></TR><TR><TD CLASS="quote">You sure it was not a rebuild? Is the Garrett tag red or green?</TD></TR></TABLE>
No Garret tag, turbo came from user Down2Turbo on ebay. Had another friend buy a turbo from him and has had no problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RogueWorks &raquo;</TD></TR><TR><TD CLASS="quote">send it back to the seller for warranty repair</TD></TR></TABLE>
That looks to be the next step, cus this thing has literally 0 miles on it.
Old Jun 30, 2006 | 10:05 AM
90LSpimpin's Avatar
I didnt resize them so u could see, so here are thumbnails.
The darkness on the right side of the housing in the first pic, isnt shadowing, its just darker.
Old Jun 30, 2006 | 01:30 PM
90LSpimpin's Avatar
Vid posted on 1st post
Old Jun 30, 2006 | 02:53 PM
RCautoworks's Avatar
Looks like the fins were hitting.
Old Jun 30, 2006 | 02:59 PM
tilt's Avatar
my fins hit on my crappy ebay turbo. the guy lied on the listing saying it was a garrett turbo. you are prob in the same boat I was in. I would do everything possible to get a refund.
Old Jun 30, 2006 | 04:47 PM
PhantomX's Avatar
your shaft is probably bent..... same thing happend to me.... damn ebayTurboz
Old Jun 30, 2006 | 04:51 PM
tepid1's Avatar
Default Re: (PhantomX)
hahaha sounds like my womans hair dryer....
Old Jun 30, 2006 | 04:53 PM
itsJDMyo's Avatar
my turbo makes a "whirring" sound, but that's because i'm running open DP. so that's how the turbo sounds like. about the the noise that seems like it's metal grinding against something, try checking your gaskets. could be a little air leak from the wastegate or something
Old Jun 30, 2006 | 06:30 PM
jDMJeRk's Avatar
Default Re: (itsJDMyo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itsJDMyo &raquo;</TD></TR><TR><TD CLASS="quote">my turbo makes a "whirring" sound, but that's because i'm running open DP. so that's how the turbo sounds like. about the the noise that seems like it's metal grinding against something, try checking your gaskets. could be a little air leak from the wastegate or something</TD></TR></TABLE>
Did you watch his vid? Its not what your describing lol
Old Jun 30, 2006 | 06:34 PM
coneheadsracing's Avatar
How do you know your getting enough oil? I used a restrictor adjuster, and if i turned it down too low, when i revved it up, it would do what yours did.
Old Jun 30, 2006 | 09:36 PM
90LSpimpin's Avatar
Default Re: (coneheadsracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coneheadsracing &raquo;</TD></TR><TR><TD CLASS="quote">How do you know your getting enough oil? I used a restrictor adjuster, and if i turned it down too low, when i revved it up, it would do what yours did.</TD></TR></TABLE>
Theres no restrictor, and its getting oil. Shaft doesnt spin straight at all whe its rev'd up. hes just ordering another turbo. sux
Old Jun 30, 2006 | 09:41 PM
project dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhantomX &raquo;</TD></TR><TR><TD CLASS="quote">your shaft is probably bent..... same thing happend to me.... damn ebayTurboz</TD></TR></TABLE>
damn down2turbo / mjm auto/ ebay specials
they're rebuilt by mjm auto down in some hick town.
not MJM turbo &lt;!~~ good company ..
i've went through 5-6 turbos with this same problem all from the same person. ( down2turbo) when i first started.. junk !!
Old Jun 30, 2006 | 09:44 PM
komat's Avatar
Default Re: (project dc2)
man i be supprise if that screen stays on the turbo without it getting sucked in after a while
Old Jun 30, 2006 | 09:52 PM
90LSpimpin's Avatar
Default Re: (komat)
Ran the super jdm screen on both of my setups in the last 2 years
never had a problem
i have more room on my new setup on the teg, so i will soon be making an intake for it
Old Jun 30, 2006 | 10:07 PM
komat's Avatar
Default Re: (90LSpimpin)
not saying screen is bad
but it seem like the screen is barely even clamps on
Old Jun 30, 2006 | 10:13 PM
90LSpimpin's Avatar
Default Re: (komat)
At that point, i dont think it was on very much, i had jsut slipped it back on so i wouldnt lose it. I wanted to look at the wheel spin directly, when it starts makin that noise, that ****** spins wild lol
vtec.dc2
Mar 28, 2007 05:56 PM
abmerop18
Mar 27, 2006 05:53 AM
komat
Oct 8, 2005 12:00 AM
selectivebeef
Jun 24, 2003 09:56 PM
MiraiZ
Nov 14, 2002 02:50 PM
