Quiet Turbo
My turbo is very quiet...I can only hear it when I'm boosting really hard, but its pretty much drowned out by the sound of rushing air...but for the most part...its completely silent....even when spooling. Is anyone experiencing the same thing?
you cant expect any turbo to make a rumbling noise!! it isnt an express train, if you're running at full boost then you may just hear a whistling or whoosing noise
That is normal. If you have a deformation or a clip in the blades you will hear the turbo whine, but under normal operation it should be quiet.
If you run an open exhaust you will hear it much louder.
Most diesel trucks will whine loudly because their turbos are huge!
Randy
Randy
The way I see it, the quieter the better.
Mine is real quiet until boosting hard. Not my friends prelude though. He has a t3/t4 on the 2.3 liter. Just cruising around you can hear it spooling a little. All you have to do i give it a little gas and it sounds like a damn jet ...tight as ****.
[Modified by MiraiZ, 7:16 AM 11/15/2002]
i can just hear a little whistling jet engine type sound out of the exhaust on open downpipe. truely bad *** to hear that for the 1st time. i'll never forget it
Smarter than you
i can hear mine spooling when i run open downpipe or when its really cold. other then that its quiet. ive noticed the turbos on some supras and eclipses sounding really mean when next to u but they are ball bearing and closed loop. could that be why?
