VTEC engages, LOUD, but no power! CTR cams...HELP PLS!
Im getting on the dyno this friday and need to figure out the source of this issue asap! Please help me out! I thought it was more civic related then in wandered into the FI realm but check this out for all the details:
https://honda-tech.com/zerothread/1674158
Intake leakage? check pipings etc
We did 280whp at 7psi with the same turbo stock b16 on a dynojet.
the turbo is big enough!
do you have any ignition issues on the engine?
plug gap?
condition of your dizzy?
plug gap?
I have a b16 with ITR cams, a drag manifold, and a t3/t4E and I put down 398whp at 17-18psi so something other than the cams is the problem. Check for a boost leak.
ill check for a boost leak with my leak tester but idk im pretty sure the entire charge side is solid, it makes and holds boost well, starts spoioling around 3k
I have a dizzy with a brand new coil and ignitor, rotor and cap may be a lil old but it wasnt missing or anything on the dyno
plug gap aroun .020 and brand new OEM wires
im running a p28 [obd1] so there is no knock sensor at all...
timing:
i was told the dotted lines were the index marks ont eh GE gears... [not the solid line]
timing:
batboyvaj
Jun 27, 2007 02:59 PM
Spooled1.6L
Mar 16, 2004 03:06 PM
