What connects to the threaded hole on turbo compressor outlet?
wow, thanks for the fast response.. Does it connect to the VACUMN or BOOST hole on the deltagate? sorry for the stupid newbie questions.
[Modified by Mucackus, 10:17 AM 4/18/2002]
It should be a 1/8" NPT threaded female hole. If you want to use it for a boost source for the wastegate or whatever, you'll need a 1/8" NPT to hose barb fitting. You should be able to get the brass ones from most automotive stores.
Dee and Dirtylude
You can connect it to the bottom port of the wastegate... i was just going to plug it and then drill a port in the intercooler piping.
Let me see if i am thinking of the right port - its the one right next to the downpipe?
underpressure02
Oct 6, 2003 08:14 AM
