turbo fitting
Old Nov 2, 2005 | 03:08 AM
Bartman201's Avatar
Default turbo fitting
i got an internal wastegate that is connected to a fitting coming out of the turbo.
if i connect the external wastegate to the vacuum manifold, can i leave the hole open on the turbo.
Old Nov 2, 2005 | 03:16 AM
BlueShadow's Avatar
Default Re: turbo fitting (Bartman201)
no, if you do not use the hole on the compressor outlet as your boost source you ned to plug it up air tight. If you leave it open you will have a boost leak. More then likely it is a 1/8 NPT port, so just get a 1/8 NPT plug with a little teflon sealant on the plug threads.
Old Nov 2, 2005 | 03:19 AM
Bartman201's Avatar
Default Re: turbo fitting (BlueShadow)
ok,thanks.
Old Nov 2, 2005 | 03:22 AM
BlueShadow's Avatar
np, but on second thought you might wanna measure the hole. I have a 1/8 NPT adapter here and the diameter is 5/16" for the outer threads. Yours looks like it might be slightly bigger. If you have a 1/8 NPT fitting (doesn't have to be a plug) and try to screw it into the hole. That will tell you if you have the correct thread pattern or not.
Old Nov 2, 2005 | 03:52 AM
White Smoke's Avatar
i my honda
Global Mod
If that's your turbonetics turbo then yes, its 1/8 NPT and you can get the plug at Lowes.
Old Nov 2, 2005 | 04:15 AM
Flashmn's Avatar
Default Re: turbo fitting (White Smoke)
You might want to use that hole as the refrence point for the wastegate, using the manifold might cause overboosting or slow wastegate response.
Old Nov 2, 2005 | 04:24 AM
Bartman201's Avatar
Default Re: turbo fitting (Flashmn)
thas not my turbo, thas just a pic i found. i got a garrett t3/t4. it has the fitting but i want to go to an external wastegate. cause with the internal the car is only boosting 2psi
Old Nov 2, 2005 | 09:38 AM
i my honda
Global Mod
Something else is wrong....
Old Nov 2, 2005 | 10:30 AM
Dee's Avatar
Dee
If you are only getting 2psi you have one of the problems below:
Major boost leak
broken actuator
bent actuator rod
malfunction flapper valve
Most likely it is the first one.
Old Nov 2, 2005 | 10:42 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: turbo fitting (Dee)
yea, sounds like a boost leak...
off topic but what kind of wg is that? looks killer
90sedan
May 31, 2007 03:17 AM
cthan3o3
Dec 28, 2005 07:17 PM
underpressure02
Oct 6, 2003 08:14 AM
KLN
Jul 1, 2002 11:16 AM
Mucackus
Apr 18, 2002 07:55 AM
