Deltagate Hookup/Vaccum Lines
Old Jun 26, 2003 | 06:58 AM
steroidguy's Avatar
Default Deltagate Hookup/Vaccum Lines
I was wondering if any of you knew what hooked up to the brass fitting on the side of the deltagate wastegate. And what hooks up to the fitting on the compressor side of the turbo. The car is builing too much boost. Thanks guys!
94 gsr-T sedan
Old Jun 26, 2003 | 07:11 AM
ykracing's Avatar
Default Re: Deltagate Hookup/Vaccum Lines (steroidguy)
the side port on the deltagate, should go to the port on the compressor side of the turbo... (easiest)
THEN the top port of the deltagate should be open unless you are running a elec. boost controller.
you are building too much boost because the wastegate isnt hooked up...
Old Jun 26, 2003 | 08:58 AM
steroidguy's Avatar
thank you so much.....you were a great help. I appreciate it.
tundra2000
Oct 20, 2010 04:54 PM
GOIN V8 HUNTIN
Dec 10, 2006 10:51 AM
DIRep972
Sep 11, 2004 01:26 PM
psi420
Dec 20, 2003 07:38 AM
_Endless_
Sep 23, 2002 10:00 PM
