*help* need to install a oil pressure gauge. but broke.
hello.
i need to install my oil pressure sensor somewhere on the engine.
i have a fasturbo oil line kit. i wanted to fit a "t" somewhere on the line but our local machine shop dont have fittings fot the 3an line.
i cant afford a sandwich plate,
where else can i read correct oil pressure from?
is it or ok to weld a fitting on the oil pan below the oil level and locate the sensor there?
thanks for any help...
i'm broke,
anyone know other press sources?
btw?
where can i buy press-on fittings like the ones on the fasturbo feed line?
(shiny silver ones
thanks
btw?
(shiny silver ones
)thanks
If you want to install a oil pressure gauge, all you have to do is get a T fitting, and on the top part of the T fitting, you need to attach your oil pressure sending unit then on the other end of the T connect to where the oil pressure sensor was then with the end sticking out just connect the end of the gauge hose to it
If you cant afford a t fitting, which is $1.25 then you shouldnt be spooln
Go to a Home Improvment store ( Home depot, Lowes) GO to there plumbing section..
They have every thing you need
if you dont have money to buy it, then steal it or somthing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro »</TD></TR><TR><TD CLASS="quote">
if you dont have money to buy it, then steal it or somthing</TD></TR></TABLE>
great advice....
great advice....
W O T
Jan 29, 2005 08:01 PM
Nextelbuddy
Jul 13, 2003 07:44 PM
