Headgasket question...?
Old May 17, 2006 | 03:50 PM
slowteg550's Avatar
Default Headgasket question...?
I bought a Golden Eagle LS/vtec kit off of ebay and when I got it, everything looked great. I finally got close to putting my head/block together, and when I put the headgasket on the block it is extremely close to the edge of the cylinder, and maybe even hanging over by like .001 in a place or two. My machinest said that if the gasket hangs over any at all it can cause detonation. I am worried about the spots that are hanging over now, and when I torque the head down, i'm afraid it will crush out even more.
Is there any thing I can do? I was considering taking a moon shaped file around it to try to give some more clearance, but I know that'd be a pain w/the 3 layer gasket.
85 mm bore pistons and gasket, but they both mic like 84.5ish
Old May 17, 2006 | 07:51 PM
slowteg550's Avatar
Default Re: Headgasket question...? (slowteg550)
Old May 17, 2006 | 09:10 PM
integraswtrde's Avatar
just make sure you don't put it backwards.
Old May 17, 2006 | 09:14 PM
b18sihatch's Avatar
Default Re: Headgasket question...? (integraswtrde)
i senond that check placement and make sure everything is lined up correctly and whatnot
Old May 18, 2006 | 03:43 AM
slowteg550's Avatar
Default Re: Headgasket question...? (b18sihatch)
Everything is lined up correctly, the metal rings go up correct? Other than up/down the dowel pins pretty much center it for you. It's just extremely close on the bore...any more info?
Old May 18, 2006 | 07:10 PM
slowteg550's Avatar
Anyone else?
Old May 19, 2006 | 03:55 AM
slowteg550's Avatar
Old May 19, 2006 | 02:58 PM
slowteg550's Avatar
Old May 19, 2006 | 09:36 PM
slowteg550's Avatar
comeone, someone has to know?
Old May 21, 2006 | 02:48 PM
slowteg550's Avatar
Old May 21, 2006 | 03:18 PM
NJIN BUILDR's Avatar
If the gasket bore measures around 84.5mm than its not a 85mm gasket.Give GE a call on Monday and get a correct one.
Old May 21, 2006 | 07:33 PM
slowteg550's Avatar
Default Re: Headgasket question...? (NJIN BUILDR)
You think they will correct it even if I bought the kit from ebay? It has the 85 mm sticker on it, but it's not..
shocker911
May 15, 2009 03:34 PM
one-cam
Jul 7, 2008 07:12 PM
92HB_HB
Sep 12, 2005 09:28 PM
1sloaccord
Mar 31, 2003 08:01 PM
forcedaccord95
Jan 29, 2003 07:29 AM
