Head Gasket Question?
Old Jan 28, 2003 | 07:49 AM
forcedaccord95's Avatar
Default Head Gasket Question?
hey guys,
I had sleeves done at darton and they bored the sleeves to big for the pistons i have so they paid the difference and bought me bigger pistons. I had wisco 85mm and now I have arias 86 mm, will the factory OEM head gasket still work that I have. It is a 1mm difference. I was told yes, because the factory head gasket is a little bigger than the factory bore (for clearance).I wanted to get you'lls opinion.please help!
thanks
Old Jan 28, 2003 | 10:22 AM
Farnsrocket's Avatar
Default Re: Head Gasket Question? (forcedaccord95)
So your gasket is 85mm and your sleeves and pistons are 86mm? I would think the crush ring on the gasket might come into contact with the edge of the cylinder and maybe not seal well. Have you placed the gasket on the block? How much hangs over (I know 1mm) but how bad does it look?
Old Jan 28, 2003 | 06:22 PM
Default Re: Head Gasket Question? (Farnsrocket)
I haven't got the block back yet. it will be here in 2 weeks, I quess it one of those trial and error things!
thanks
Old Jan 29, 2003 | 12:17 AM
Flamenco-T's Avatar
you can prolly get away with 0.5mm, not sure about 1mm...service limit is 0.5mm...I use stock headgasket on 81.5mm bore
get a sandpaper and sand the edges of the headgasket lil bit to get it a lil larger...never tried it, but don;t see why it won't work..
Old Jan 29, 2003 | 12:28 AM
ninesecrx's Avatar
Default Re: Head Gasket Question? (Flamenco-T)
send the gasket to darton and have them match port it...
Old Jan 29, 2003 | 07:29 AM
Default Re: Head Gasket Question? (ninesecrx)
thanks for the quick replys guys, you have been a huge help! I called the machine shop after reading the last post (THANKS TO NINESCRX) and earl at edge brothers machine, he measured the clearance on the head gasket. he said it would be fine and that I did not have to do to the overbore on the gasket. he said that the factory overbores it for clearance from factory! thanks again!
shane
EJ8_Man
Jun 25, 2010 10:16 AM
reek
May 3, 2005 01:38 PM
vangc6780
Jun 24, 2004 04:50 PM
Rspec CX
Apr 16, 2004 08:10 AM
jt-sport
11
Feb 11, 2004 02:57 PM
