Hondata rev limiter?
Old May 21, 2006 | 02:13 PM
96Spec Ek's Avatar
Default Hondata rev limiter?
I have searched and found that there is a way to set the rev limiter with the button with the S200. koeo "key on engine off" hit button 5 times, hit brake, set thousands hit brake, set hundeds hit brake, turn key to off position, wait ten seconds, then turn on car.
This hasn't worked for me. The rev limiter is at 8400. I can set it as low as 4000 to see if this way of setting it works and it does. Anyone know why I cant get it above 8400? Ive got a b16 sir2 with skunk2 cams and valvetrain and on the dyno at school it was still making power when it slams into the rev limiter . By the way so far with stock block it put down 168.53 whp and 111.67 wtq on a dyno jet
Someone help me out here please
Old May 21, 2006 | 03:09 PM
NJIN BUILDR's Avatar
Default Re: Hondata rev limiter? (96Spec Ek)
http://www.hondata.com/downloads/Users%20Guide.doc
You can set it with the engine running.It's half speed,you rev to 4000 and it will set it to 8000.I haven't done this with the button as I have a romulater and don't reset peak rpm limit very often.I do know it works with flat shift and launch as I have done those on the fly before.
Glenn
Old May 21, 2006 | 04:46 PM
96Spec Ek's Avatar
Default Re: Hondata rev limiter? (NJIN BUILDR)
Ok I guess I'll try it that way. It isn't going to be as accurate though.
Old May 21, 2006 | 06:12 PM
If you have datalogging you can verify the limit you set.It may take a couple tries to get it where you want.
Old May 21, 2006 | 07:41 PM
96Spec Ek's Avatar
Yes I have datalogging but my laptop sucks, it dies after charging it all night within 15 minutes. But yea that will assure me of what rpm I have set it at. Thanks man
04Sispeed
Apr 25, 2005 04:10 AM
digital sol
Jan 2, 2005 08:49 PM
EF_LSVtec
Apr 16, 2003 09:28 AM
