autometer elelctric oil gauge....need help!!
well its pretty easy the instructions that come with it are all u mostly need but you use the spot for the stock oil pressure sender or get the adapter for your oil filter but i used the oe sending unit spot and got a steel braided brake line from napa for 12 bucks and they have all the different connectors there that are like $1 a piece. You mount the oil pressure sending unit on the firewall somewhere and run the steel braided line to it.Instead of buying the steel braided lines off line for 40-60 bucks. I also left the stock oil sender unpluged cuz you really dont need it if you have a oil pressure gauge.
If you use search im sure there are right ups on it with pics
W O T
Jan 29, 2005 08:01 PM
Nextelbuddy
Jul 13, 2003 07:44 PM
