valve adjustment upon ctr intake cam installation.....
hey guys, i just ordered my ctr intake cam and ill be dropping it in my gsr motor.... im guessing i need to adjust the valves for the larger cam? and what are the clearances i need? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">You dont need to adjust the valves. If you want just check them make sure there within specs (use regular honda specs) </TD></TR></TABLE>
x2
But if you feel like double checking its
Intake .006-.007
Exhaust .007-.008
x2
Intake .006-.007
Exhaust .007-.008
ok i searched for it and couldnt find anything. ok and if my valves need to be adjusted would that be causing my vtec to work half ***. and i know they need to be adjusted cuz u can hear tappping the whole valvetrain is noisy
if the adjusters are badly out of spec it may make a difference in power. you definately want to check them any time the cam caps/valvetrain come up... might as well... more recently i have seen a lot of cars that run like crap because the ignition timing was off. maybe not your problem, but if you haven't checked it, you should.
