CTR cam and valve adjustment
CTR intake cam in a gsr head.
do i set the valves the same as if i had the stock gsr intake cam...at .007?
i just put the cam in and i'm assuming i will need to do another valve job since the
CTR cam is a little bigger than the gsr cam.
thanks
thanks
Re: CTR cam and valve adjustment (hondaeg8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote">CTR intake cam in a gsr head.
thanks</TD></TR></TABLE>
Let me know what you end up doing. I'm getting machine work done to my B16 head based off its CT-R cams to take advantage of its full potential.
Re: CTR cam and valve adjustment (TallAssFilipino)
i'm thinking the valve gap is the same, .007. i just want to make sure.
my friend has a 01 itr motor and the CTR intake cam is the same as his cam. the valve spec on his intake cam is .006-.007. so i'm thinking its the same for the CTR, but i'm not sure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 »</TD></TR><TR><TD CLASS="quote">i'm thinking the valve gap is the same, .007. i just want to make sure.
my friend has a 01 itr motor and the CTR intake cam is the same as his cam. the valve spec on his intake cam is .006-.007. so i'm thinking its the same for the CTR, but i'm not sure. </TD></TR></TABLE>
Set the lash the same as you would with stock cams.
