BYPASS OIL PRESSURE SENSOR FOR VTEC?
How exactly is this done, Guys?
edit: sorry, 98 jdm b18c, trying to get obd-1 p72 ecu to work..........can understand how to ground the vtec pressure sensor wire going into the ecu......Help please. isnt there a way Around getting a USDM Vtec Senor? Thnaks again
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
If you have an obd1 p72 ecu... We can reprogram it and remove the vtec oil pressure chech as well as knock sensor ,eld, ect .. Please feel free to contact us at the shop or AIM WHITFLDRACINGINC
how much $$$ ? I apprecitate the "help" but there is an easy way to get around this.....and wiring is the answer
thnaks, man.......so iT wouldnt runn any worse than if I had a usdm vtec solinoid/pressure sensor, wired up? just run the wire out of the ecu plugs? my engine bay only has one clip for the JDM solinoid. I also have a step down harness from boomslang. should I run the wire starting from the clips of my harness? what color arethey....sry....im a noob. lemme check those links of yours whil;e im at it.....and thanks alot , man..
thank to all who helped me......and were very patient with my feeble mind.........okay dude all you do.......is: on the plugs going INTO your ECU, locate a4 and d6............clip d6(on the ECU Clip side) and strip a bit of rubber off the tip(enough to wrap around another wire) , next- shave the rubber off of the wire comming out of a4 and "T" Splice it.........which means just wrap D6 around A4 and tape it up. I havent had any check engine and the motor HAULS ***!!!!!! OBD-1 BABY!!!
GOOD LUCK!!!!
GOOD LUCK!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkanedtx »</TD></TR><TR><TD CLASS="quote">easy right</TD></TR></TABLE>
sa210coupe
Nov 26, 2006 04:56 PM
vegaskurt
Jun 20, 2006 09:31 PM
BoostinEJ1
Jun 13, 2006 09:22 AM
racetek82
Jan 26, 2005 10:16 AM
