wiring vtec
Old Jul 5, 2003 | 08:55 PM
b16hybridsol's Avatar
Default wiring vtec
i have a 94 ls and put an obd1 gsr motor into it, i'm using the ls harness though. does someone have the pin out for the vtec wires?
Old Jul 5, 2003 | 09:35 PM
wanttorace's Avatar
Default Re: wiring vtec (b16hybridsol)
i need it too help someone
Old Jul 5, 2003 | 10:32 PM
salbaje's Avatar
D3 for the knock sensor
vtec solenoid must be pinned in at A4.
The vtec oil pressure must go to D6.
Iab in a17
Old Jul 5, 2003 | 10:51 PM
JV's Avatar
JV
Who?
Courtesy of the Katman...
Old Jul 6, 2003 | 08:34 AM
Default Re: wiring vtec (JV)
thanks guys i'll let ya know how it goes
Old Jul 8, 2003 | 01:57 PM
can someone take a picture of their motor, and high light what wire is what. Because i don't have a helms manual, and i just got the car today, and it looks like vtec is all wired up, but the kid told me it needed wired. I'll try to get pics on tonight but can someone help me out till then
Old Jul 8, 2003 | 03:06 PM
poison's Avatar
Are you throwing any codes?
The VTEC solenoid is a green plug with a Grn/Wht wire, then goes to the Grn/Yel in the engine harness, then to the shock tower being an Org/Wht wire.
Oil Pressure sensor is Blu/Blk wire to a Org/Blue wire.
Oil Pressure sensor ground is Blk which is the thermostat ground.
HTH.
Old Jul 8, 2003 | 03:29 PM
JV's Avatar
JV
Who?
Default Re: wiring vtec (poison)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by poison &raquo;</TD></TR><TR><TD CLASS="quote">Are you throwing any codes?
HTH.</TD></TR></TABLE>
Just to back up this guy here...
Old Jul 8, 2003 | 03:47 PM
bew
Guest
Posts: n/a
Whoa.... question here. It shows the VTM going from the ECU to the VTEC pressure switch. Ok, I understand that. BUT, on my v-afc, I have the blue wire coming from the vafc not being used. This is the VTM wire for the vafc if its needed, but the diagram above shows that there is a VTM and it is being used. So where does the vtm wire from the vafc splice into?
Old Jul 8, 2003 | 07:18 PM
Turbo Powa's Avatar
Default Re: wiring vtec (bew)
FYI, I also had a vafc. Didnt need to hook up the VTM wire.
Arthas
Apr 23, 2012 01:30 PM
94EGKUSH
Mar 2, 2009 09:19 AM
sa210coupe
Nov 26, 2006 04:56 PM
Baggy Spandex
Jul 15, 2003 12:50 PM
takeheed
Sep 16, 2002 06:48 PM
