electrical problem
I got all of my zc in today, and I went to put the positive and negative on the battery it started making a crackling noise. What the heck does that mean??? when i tur the key nothing turns on when they are connected
OK, I've narrowed it down. I can get everything to work right, except when i connect the positive to the starter. Once the positive is connected to the starter everything is shorted out. What does that mean???
it means you need to recheck any and all connection you may have made on the engine harness. and also check it for rips or cuts. you either have a 12v wire to ground or something is chaffing against metal.
hondachris1994
12
Nov 9, 2017 05:15 PM
92EG8
14
Aug 25, 2007 12:11 AM
