h22 into del sol question about shift linkage
Old Apr 25, 2006 | 02:53 PM
pilmpd's Avatar
Default h22 into del sol question about shift linkage
i have run into a problem with a h22 swap. the del sol shifter is further back than an eg civic, thus the cables are to short. anyone have ne suggestions on how to get this to work. i have searched but havent found nething about this
Old Apr 25, 2006 | 03:42 PM
mikegeezy's Avatar
Default Re: h22 into del sol question about shift linkage (pilmpd)
you can place the prelude shifter newhere you want cuz you have to cut neway.
Old Apr 25, 2006 | 03:51 PM
pilmpd's Avatar
Default Re: h22 into del sol question about shift linkage (mikegeezy)
if i do that the shifter will be in the dash..
Old Apr 25, 2006 | 08:34 PM
h22chilton's Avatar
* B A N N E D *
here ya go: here my eg sedan;
Old Apr 26, 2006 | 07:39 AM
pilmpd's Avatar
well I wish I could thank you guys for the help, but as of yet I have yet to be guided in the right direction. I am well aware of cuting and placing the shifter box where ever it needs to go. However, the shifter location of a del sol is about 3" further back then the eg shifter location. So if the shifter box was moved 3" further forward then it would be inside the dash. So back to my original question. Does anyone know how to overcome this problem in a del sol, not an eg civic? Any real help would be appreciated.
Thanks
Old Apr 26, 2006 | 08:52 AM
dlric's Avatar
Default Re: (pilmpd)
bump this up because i have the same q
Old Apr 28, 2006 | 03:17 PM
h22chilton's Avatar
* B A N N E D *
get your center console out, HOOK UP THE LINKAGE on the tranny, and place it where you want, on the exhaust tunnel any way! thats how i determined where to cut. . move the shifter from side to side to be sure the bulky thing won't hit the console, my nuespeed shifter kit, pictured above hit my console, good thing i don't use one any way!
Old Apr 29, 2006 | 07:04 AM
cpforyou's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pilmpd &raquo;</TD></TR><TR><TD CLASS="quote">well I wish I could thank you guys for the help, but as of yet I have yet to be guided in the right direction. I am well aware of cuting and placing the shifter box where ever it needs to go. However, the shifter location of a del sol is about 3" further back then the eg shifter location. So if the shifter box was moved 3" further forward then it would be inside the dash. So back to my original question. Does anyone know how to overcome this problem in a del sol, not an eg civic? Any real help would be appreciated.
Thanks</TD></TR></TABLE>
I know a place where you can send in your current shifters, and they will rebuild it for you (brand new components) and make it longer to your specs.
Old Apr 29, 2006 | 11:07 AM
teknics1's Avatar
I have done the h22 into a sol, and you should have no problem with the shifter. Place it in the exact position as the stock sol shifter and cut out a little more of the hole for the prelude shifter. You will have to notch out the front subframe and run the cables up next to the firewall. This is how I did mine and never had a problem with it. If you give me your email address, I will send you pics of it.
wstmsol
Oct 20, 2011 08:40 PM
9k Swag
Aug 11, 2011 07:18 PM
9k Swag
Aug 8, 2011 11:08 AM
jerryscherry
11
Jan 20, 2010 05:57 PM
95lscivic
Aug 12, 2009 03:58 PM
