What size flange to fit end on 3" Thermal? (making my own flex)
Old Apr 8, 2002 | 09:28 AM
Chip398193's Avatar
New User
Default What size flange to fit end on 3" Thermal? (making my own flex)
i have a soon to be boosted LS.I'm gonna make a "flex pipe" i guess you could call it, out of exhaust repair kit...as seen here https://honda-tech.com/zerothread?id=155616 . i will be ordering a 3" thermal in about 2 weeks. I need to make the flange that hooks up to the exhaust...but i'd like to have it made before my exhaust comes in so i dont have to wait to put it on. Anyway i can tell an exhaust shop waht size flange i need.....or am i just going to have to wait till my exhaust comes in and bring it to them? Thanks
Old Apr 8, 2002 | 07:43 PM
The Mick's Avatar
Default Re: What size flange to fit end on 3" Thermal? (Chip398193)
Try SummitRacing.com
For 3" to 3" (if you have a 3" downpipe & flex)
part # SUM-G4752
or
part # SUM-G4752SS if you prefer stainless.
For 2.5" to 3"
part # SUM-G4754
or
part # SUM-G4754SS for stainless
You get 2 of 'em, so you can give one to your friend.
[Modified by The Mick, 11:46 PM 4/8/2002]
Old Apr 8, 2002 | 10:56 PM
blkDOHCsol's Avatar
New User
Default Re: What size flange to fit end on 3" Thermal? (The Mick)
does the flex come before or after the flange?
Old Apr 9, 2002 | 05:06 AM
Chip398193's Avatar
New User
Default Re: What size flange to fit end on 3" Thermal? (blkDOHCsol)
i see 3" to 2.5 inch exhaust, but i need 2.5" downpipe to 3" exhaust...i cant seem to find it on there.
Old Apr 9, 2002 | 05:55 AM
_Shadow_'s Avatar
New User
I know this will blow your mind but all you have to do it turn it around
Old Apr 9, 2002 | 06:20 AM
Smashback's Avatar
Default Re: What size flange to fit end on 3" Thermal? (_Shadow_)
Hehe, no, these are one-way directional flanges...
Old Apr 9, 2002 | 07:37 AM
rtype11's Avatar
I am not sure but do you need a reducer donut or someting? Chrysler has a donut reducer from 3 to 2.5", dont remember what car it came off though.
Old Apr 10, 2002 | 07:48 AM
Chip398193's Avatar
New User
no......i need the flange to bolt up to the 3" side and the 2.5 inch pipe to be open....
Old Apr 10, 2002 | 02:20 PM
The Mick's Avatar
The 2.5" to 3" flange I listed above should do the trick. Just bolt that flange to your 3" exhaust, then use some 2.5" flex tube as seen in the pic in this link: http://imglib.************/index.cgi?cmd=view&id=2396 Connect one end of the flex tube to the 2.5" downpipe with a U-bolt, and use another U-bolt to connect the 2.5" flex tube to the 2.5" - 3" flange I listed above... just like in Dustin's pic.
Unless I'm missing something.
Old Apr 11, 2002 | 10:03 AM
Chip398193's Avatar
New User
ahh i see what your saying. just one question...is that bolt pattern for the flange universal?like will it def. bolt up to my 3"thermal?
Old Apr 11, 2002 | 11:26 AM
Trigun's Avatar
http://imglib.************/index.cgi?...wimage&id=3131
from this pic, it looks like the summit 3" flange will bolt on to the thermal.
Old Apr 14, 2002 | 08:05 PM
The Mick's Avatar
The one that comes with the Thermal has a 3" hole with a 4" diameter bolt circle. (from the center of the 3" hole to the center of one of the small holes on the flange is 2")
Your 3" Thermal exhaust should have one of these provided. But, if you can't wait, that should be the info you need to be sure you're ordering the right one from Summit (or whoever).
[Modified by The Mick, 12:09 AM 4/15/2002]
Scott53092
Feb 12, 2014 12:54 PM
hatchinprogress
Welding / Fabrication
Mar 19, 2006 03:17 PM
DSPDA3
Feb 9, 2005 06:17 AM
Vtec92Civic
Oct 20, 2004 02:07 PM
cjb80
Feb 18, 2003 08:44 AM
