Greddy Type S Help
Old Apr 17, 2006 | 10:47 AM
NosCivic01's Avatar
Default Greddy Type S Help
i have a gsr with a greddy type s bov. wanted to know a few things about it
1) at idle the bov is open a little bit. is this normal? i hear air coming through it.
2) when i drive the car n step off the gas its blows off and then it makes a wistleing noise after it blows off like 2-3 sec after im off the gas. its really annoying. wat could b wrong? i have the screw in till it stops.
this happened after i took my motor out to build it n when i installed everything its different. could the bov be broken? or is my vacum messed up? i have it installed on the top nipple. n its vacumm line is to throttle body vacum T'd off . any ideas?
Old Apr 17, 2006 | 11:48 AM
99B16Si's Avatar
all of that is normal
Old Apr 17, 2006 | 11:59 AM
NosCivic01's Avatar
Default Re: (99B16Si)
realy? but it never did that before i took the motor out? neway that i could have vacuum lines messed up?
Old Apr 17, 2006 | 12:32 PM
99B16Si's Avatar
its possible its seeing slightly different vacuum due to the way you routed your vacuum lines this time around. try setting the spring a bit stiffer if its annoying you
Old Apr 17, 2006 | 12:46 PM
NosCivic01's Avatar
thats the thing its in all the way...i dono y it does that. after it blows off, like 4 sec later it wistles. its getting annoying. i dono if the bov is broken?
Old Apr 17, 2006 | 12:50 PM
99B16Si's Avatar
all of the type s's ive heard do that.
Old Apr 17, 2006 | 02:55 PM
BoostedGreddy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NosCivic01 &raquo;</TD></TR><TR><TD CLASS="quote">thats the thing its in all the way...i dono y it does that. after it blows off, like 4 sec later it wistles. its getting annoying. i dono if the bov is broken?</TD></TR></TABLE>
thats normall.. the type S is supposed to blow then whistle .. that the reason i bought mine
Old Apr 17, 2006 | 04:45 PM
99TurboEM1's Avatar
ya, the type S does blow off for quite some time, I like it, and that is why I use it.
On a side note, if you want the "laser" sound to stop you can always plug the second port on the type S with a line that comes from your turbo.
Old Apr 20, 2006 | 09:36 AM
NosCivic01's Avatar
Default Re: (99TurboEM1)
but the line that comes from the turbo is going to my wastegate with a boost controller in b/t. wat else can i do
4dek
Jun 1, 2008 05:39 AM
B16Civic93
Mar 8, 2005 07:36 AM
GDM Z28
Mar 4, 2004 05:54 PM
Trigun
Nov 30, 2002 02:19 PM
td04civic
Dec 18, 2001 08:09 PM
