not blowin off?
Old May 29, 2008 | 08:46 PM
4dek's Avatar
Default not blowin off?
i can hear my turbo surge and my bov not blowin off, i have the greddy type s bov and it is set to the softest but still wont open or is that the bov i hear?pls help
Old May 29, 2008 | 09:07 PM
da_dude's Avatar
Test it out by pressing on the throttle on the throttle body and looking at the bov. Sound like your vacuum source is bad.
Old May 30, 2008 | 03:07 PM
4dek's Avatar
Default Re: (da_dude)
nope bov is not opening. vacuum sucks hard when i disconnected it and put my finger on the hose
Old May 30, 2008 | 05:27 PM
chimmike's Avatar
Default Re: (4dek)
what bov are you using? Does it have an adjustment screw? If so, is it too tight? (i.e. screwed in too much?)
try loosening the screw (unscrewing it some) and test it. Don't do it a lot, but try little by little.
Old May 30, 2008 | 05:34 PM
Haza45's Avatar
Default Re: not blowin off? (4dek)
I concur sounds like vacuum is weak. How large is the line and where is it plumbed too which port on the IM
Old May 30, 2008 | 06:06 PM
da_dude's Avatar
Open it up and check the diaphragm for wear and tear.
Old May 30, 2008 | 07:33 PM
hotrod99's Avatar
I had the same problem,and it ended up being a hole in the vacuum line...so you might wanna check the hose,could've melted somewhere
Old May 30, 2008 | 08:45 PM
4dek's Avatar
Default Re: (hotrod99)
its the greddy type s bought it new. no leaks in the vacuum just checked it.adjusted it to soft but still not working. havent installed a boost gauge yet and i think its boosting just a little maybe thats why it doesnt have enough pressure to push the valve in the bov?
before intalling the bov i tried pressing the valve to open using my fingers (curiosity) and its pretty stiff. can be the bov defective or this is just normal? does the boosted air from the turbo help the vacuum on the bov open the valves or is it just the vacuum that opens it?
the vaccum line came with bov and it has its own vacuum source
Modified by 4dek at 10:05 PM 5/30/2008
Old May 30, 2008 | 09:06 PM
da_dude's Avatar
Where did you buy a greddy type s brand new? Last time I remember the greddy type s was discontinue for a while now. Are you sure you it's not the greddy type rs bov instead?
Old May 30, 2008 | 09:09 PM
4dek's Avatar
i bought it from a friend
Old May 30, 2008 | 09:13 PM
da_dude's Avatar
Well, you can alway open it up and take one of the two springs out. I had to do this to my greddy rs bov too as it was too stiff and I would get compressor surge with part throttle.
Old May 30, 2008 | 09:24 PM
4dek's Avatar
and also i cant hear that sound (either bov or surge) while reving the car at a standstill..Why?
Old May 30, 2008 | 09:37 PM
da_dude's Avatar
Default Re: (4dek)
What turbo are you running? How high of the rev did you rev it to?
Old May 30, 2008 | 10:08 PM
4dek's Avatar
turbonetics t04e .63 .50. revved it around 5500
Old May 30, 2008 | 10:10 PM
da_dude's Avatar
Like I said before open the bov and take one of the spring out and get back to us. Maybe post some pics up too.
Old May 30, 2008 | 11:01 PM
4dek's Avatar
il try that tomorrow (stupid neighbors). il post tomorrow
Old May 31, 2008 | 04:25 AM
chimmike's Avatar
Default Re: (4dek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek &raquo;</TD></TR><TR><TD CLASS="quote">and also i cant hear that sound (either bov or surge) while reving the car at a standstill..Why?</TD></TR></TABLE>
you'll never create boost while revving standing still because there's no load on the motor, therefore your BOV will never go off. Especially running that t3/t4.
You really need to get a boost gauge! this will tell you whether or not you're in fact making boost!
And yes, check the vac line. No greddy type S I've ever seen has been too stiff to blow off even 7psi from a t3/t4.
Old May 31, 2008 | 11:14 AM
4dek's Avatar
Default Re: (chimmike)
then why do some cars revin while at the stop light and can hear the bov blowin off?
Old May 31, 2008 | 11:18 AM
SovXietday's Avatar
Default Re: (4dek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dek &raquo;</TD></TR><TR><TD CLASS="quote">then why do some cars revin while at the stop light and can hear the bov blowin off?</TD></TR></TABLE>
Because it's a GTI running a turbo the size of a pencil eraser.
Old May 31, 2008 | 09:44 PM
da_dude's Avatar
My sc34 make enough boost to blow off at idle. Nothing like how a eclipse does it but can still do the job to check if the bov is working.
Old Jun 1, 2008 | 05:39 AM
chimmike's Avatar
then something isnt' right, you shouldn't be able to do that, or your BOV is adjusted too tight.
2004es2
Mar 16, 2009 12:54 AM
vy3tnamezz
Jul 17, 2008 09:59 AM
wambus
Sep 18, 2006 03:31 AM
FOrSfEd
Mar 20, 2004 10:44 AM
wickedxboi
May 21, 2003 08:33 PM
