what will happen if I retard timing all the way?
Old Apr 6, 2002 | 03:50 PM
infamousALLMTR's Avatar
Default what will happen if I retard timing all the way?
I know if you advance to a point you will hear detonation, but what if I retard all the way? I am wondering this because I will be running 12:1 compresion pistons and I want to retard it all the way So I dont detonate. Good Idea or bad?
Old Apr 6, 2002 | 03:51 PM
rainforest's Avatar
Default Re: what will happen if I retard timing all the way? (infamousRRH)
you car will be sluggesh and not want to burn the fuel.
Old Apr 6, 2002 | 04:00 PM
Default Re: what will happen if I retard timing all the way? (rainforest)
so I should do this right away and then slowly advance the timing right? intill I here detonation then I should back off. Right?
Old Apr 6, 2002 | 04:28 PM
No More Civic's Avatar
What are you using for tuning? With 12:1 compression, I hope you are using a stand alone. Let us know what your setup is so we can better help you.
Old Apr 6, 2002 | 04:42 PM
Default Re: what will happen if I retard timing all the way? (SlowCivicDX)
I will break her in with a p28 mated w/mugen chip then I will go hondata stage3, here is my setup if this better helps you. https://honda-tech.com/zerothread?id=149535
[Modified by infamousRRH, 6:15 PM 4/6/2002]
Oct 20, 2003 02:39 PM
wzcb08
May 19, 2003 07:47 PM
shermanyang
Feb 27, 2003 05:53 PM
echo999
May 19, 2002 02:28 AM
blazin
Dec 2, 2001 07:58 PM
