ECU question
Old Apr 2, 2006 | 12:58 AM
CLE's Avatar
CLE
Default ECU question
Is an ecu for an automatic car different from a standard one? Swapping 90 integra engine into crx, its automatic car, wondering if I can use that ecu.
Old Apr 2, 2006 | 03:28 AM
si0385.'s Avatar
i believe you can use an auto ecu in a manual but not a manual in an auto car...
i could be wrong though im not sure
Old Apr 2, 2006 | 04:37 AM
yellowrexsi's Avatar
Default Re: (si0385.)
It will work, but it will through a code.
Old Apr 2, 2006 | 08:52 PM
CLE's Avatar
CLE
Default Re: (yellowrexsi)
a code? is there any other downside besides cel light?
Old Apr 2, 2006 | 08:55 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: (CLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLE &raquo;</TD></TR><TR><TD CLASS="quote">a code? is there any other downside besides cel light?</TD></TR></TABLE>
Yes, it won't idle properly
Old Apr 3, 2006 | 10:12 AM
CLE's Avatar
CLE
So I would be better of just keeping the crx ecu in?
Old Apr 3, 2006 | 10:54 AM
Mach69's Avatar
Default Re: (CLE)
Do not use the CRX ecu. NO!
Just get a manual ecu for the engine you are swapping in.
Old Apr 3, 2006 | 11:35 AM
CLE's Avatar
CLE
I didn't wanna hear that 8/// currently I have an auto ecu, ill try to find a manual one,
What do I have to change if I wanna switch to p28 and convert to obd-1? im planning on going b16 and then after that b20/vtec so im gonna need it anyways. Is it just the dizzy I switch out? then do the wiring. Or can I somehow use the same obd-0 dizzy off the ls engine I have.
Old Apr 3, 2006 | 05:12 PM
Mach69's Avatar
Default Re: (CLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLE &raquo;</TD></TR><TR><TD CLASS="quote">I didn't wanna hear that 8/// currently I have an auto ecu, ill try to find a manual one,
What do I have to change if I wanna switch to p28 and convert to obd-1? im planning on going b16 and then after that b20/vtec so im gonna need it anyways. Is it just the dizzy I switch out? then do the wiring. Or can I somehow use the same obd-0 dizzy off the ls engine I have.</TD></TR></TABLE>
I hope you chip the p28 because with stock fuel maps, it wont work. To convert to obd-1, you will need a obd-1 distributor, obd0-obd1 conversion harness (www.rywire.com), 4 wire 02 sensor, and obviously an obd-1 ecu.
luder916
Feb 11, 2009 08:37 PM
irideslammed5021
Jun 29, 2006 11:45 AM
ringgold
Sep 29, 2004 12:02 PM
Btothe3rdDegree
Jun 27, 2004 06:51 PM
JDMCIV95
Nov 21, 2002 06:30 PM
