ECU question
Crazy Honda Guy
Re: (CLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLE »</TD></TR><TR><TD CLASS="quote">a code? is there any other downside besides cel light?</TD></TR></TABLE>
Yes, it won't idle properly
I didn't wanna hear that 8/// currently I have an auto ecu, ill try to find a manual one,
What do I have to change if I wanna switch to p28 and convert to obd-1? im planning on going b16 and then after that b20/vtec so im gonna need it anyways. Is it just the dizzy I switch out? then do the wiring. Or can I somehow use the same obd-0 dizzy off the ls engine I have.
Re: (CLE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CLE »</TD></TR><TR><TD CLASS="quote">I didn't wanna hear that 8/// currently I have an auto ecu, ill try to find a manual one,
What do I have to change if I wanna switch to p28 and convert to obd-1? im planning on going b16 and then after that b20/vtec so im gonna need it anyways. Is it just the dizzy I switch out? then do the wiring. Or can I somehow use the same obd-0 dizzy off the ls engine I have.</TD></TR></TABLE>
I hope you chip the p28 because with stock fuel maps, it wont work. To convert to obd-1, you will need a obd-1 distributor, obd0-obd1 conversion harness (www.rywire.com), 4 wire 02 sensor, and obviously an obd-1 ecu.
ringgold
09-29-2004 12:02 PM
Btothe3rdDegree
06-27-2004 06:51 PM
