del Sol fuel pump
Old Apr 1, 2006 | 12:00 PM
The Real Lazarus's Avatar
Default del Sol fuel pump
I got my car back from the alarm place yesterday and it drove fine. Put the interior back in this afternoon and wanted to listen to my stereo so I switched on the key...didn't hear the fuel pump at all. THought it was my kill swicthes so I pulled the interior out and connected the fuel pump back to stock...still nothing.
In the process of connecting my fuel pump I disconnected the negative terminal on the battery and when I reconnected it the alarm threw a ****. Finally got that disarmed, but am still having problems with the fuel pump. The car cranks but the pump doesn't work; surely the pump didn't just up and die overnight.
Old Apr 1, 2006 | 12:04 PM
8520's Avatar
Default Re: del Sol fuel pump (The Real Lazarus)
Laz, your alarm sucks
Didn't know you came on ht
Old Apr 1, 2006 | 12:06 PM
Default Re: del Sol fuel pump (got_no_sol)
Up your bum! I come on here because I knew no-on one SS (that's logged on right now) would be any use....help me!!
Old Apr 1, 2006 | 12:33 PM
8520's Avatar
It's gotta be a kill switch issue, most alarms do not have a fuel pump cut circuit.
If it's turning over it's obviously not the start kill, so hmm......
Old Apr 1, 2006 | 12:34 PM
imm0rt41's Avatar
Do you have another known-good pump to test it with? If so, try it to rule out whether or not your pump is bad.
If the known-good pump is bad too then you know the problem lies in the wiring and not the part itself.
Old Apr 1, 2006 | 01:05 PM
Default Re: (imm0rt41)
Pump was ok late last night and I have no reason to believe it would mysteriously die in the night.
Known things that have changed from last night;
- Interior panels back in
- Alarm went haywire, disarmed it
- Took interior panels out and hooked up fuel pump (taking kill switches from the circuit)
So, I'm wondering would a fuse have blown, relay died, or do you think my alarm is locking me out due to the fact it thinks I was trying to steal it? Stupid DEI only has Mon-Fri phone hours
Old Apr 1, 2006 | 01:54 PM
Anyone...Bueller?
Old Apr 1, 2006 | 02:09 PM
8520's Avatar
Default Re: (The Real Lazarus)
I assume you've checked all your fuses?
Old Apr 1, 2006 | 03:04 PM
Default Re: (got_no_sol)
Just went out and got some, replaced the 7.5 amp fuel pump one and 15 amp ecm one....heard the fuel pump whir....**happy dance** I'm back on track for Vegas Invasion
Old Apr 2, 2006 | 06:25 PM
8520's Avatar
I win
Old Apr 2, 2006 | 06:32 PM
imm0rt41's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Real Lazarus &raquo;</TD></TR><TR><TD CLASS="quote">Just went out and got some, replaced the 7.5 amp fuel pump one and 15 amp ecm one....heard the fuel pump whir....**happy dance** I'm back on track for Vegas Invasion </TD></TR></TABLE>w00t see you there!
wickedplastikman
Mar 9, 2010 04:24 PM
nafreak
Aug 10, 2006 05:17 PM
JDM_Andrew
Mar 24, 2006 07:57 AM
d16y8delsol
Feb 21, 2006 09:26 PM
Quik Chris
Oct 9, 2002 06:50 PM
