Should I even bother fixing this?
Old Mar 31, 2006 | 08:26 AM
ahemming06's Avatar
Default Should I even bother fixing this?
Have a check engine light that comes on about 10 mins after I start driving every time that kicks on due to a knock sensor code. The car seems to run quick and hard even still but is this a problem that I should fix or is this handicapping my car? I was told this makes my car run slower, is this true?
96 gsr motor swapped into 95 civic ex (ej) with an obd1 gsr ecu.
Old Mar 31, 2006 | 08:27 AM
Luserkid's Avatar
Default Re: Should I even bother fixing this? (ahemming06)
run a chipped ecu, problem solved. (with a GSR base)
Old Mar 31, 2006 | 08:34 AM
ahemming06's Avatar
Default Re: Should I even bother fixing this? (Luserkid)
My ECU is chipped, but it doesnt bypass the knock sensor, I guess it has a larger fuel map so VTEC kicks harder. So I just need to find someone to take my ecu to and have the knock sensor bypassed?
Old Mar 31, 2006 | 08:49 AM
ahemming06's Avatar
bump
Old Mar 31, 2006 | 09:47 AM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahemming06 &raquo;</TD></TR><TR><TD CLASS="quote"> Have a check engine light that comes on about 10 mins after I start driving every time that kicks on due to a knock sensor code. The car seems to run quick and hard even still but is this a problem that I should fix or is this handicapping my car? I was told this makes my car run slower, is this true?
96 gsr motor swapped into 95 civic ex (ej) with an obd1 gsr ecu.</TD></TR></TABLE>
fix the problem, the engine light comes on for good reasons...
Old Mar 31, 2006 | 10:45 AM
2slo2serious's Avatar
check engine light
GaryTuesday
Aug 13, 2013 01:03 PM
adam081904
Mar 28, 2008 07:30 AM
bak lee
Jul 26, 2005 08:58 AM
tek_civic
Aug 8, 2003 03:36 PM
hatchboy93
21
Apr 25, 2003 09:57 PM
