Should I even bother fixing this?
Have a check engine light that comes on about 10 mins after I start driving every time that kicks on due to a knock sensor code. The car seems to run quick and hard even still but is this a problem that I should fix or is this handicapping my car? I was told this makes my car run slower, is this true?
96 gsr motor swapped into 95 civic ex (ej) with an obd1 gsr ecu.
Re: Should I even bother fixing this? (Luserkid)
My ECU is chipped, but it doesnt bypass the knock sensor, I guess it has a larger fuel map so VTEC kicks harder. So I just need to find someone to take my ecu to and have the knock sensor bypassed?
Re: Should I even bother fixing this? (ahemming06)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahemming06 »</TD></TR><TR><TD CLASS="quote"> Have a check engine light that comes on about 10 mins after I start driving every time that kicks on due to a knock sensor code. The car seems to run quick and hard even still but is this a problem that I should fix or is this handicapping my car? I was told this makes my car run slower, is this true?
96 gsr motor swapped into 95 civic ex (ej) with an obd1 gsr ecu.</TD></TR></TABLE>
fix the problem, the engine light comes on for good reasons...
tek_civic
08-08-2003 03:36 PM
