NEED HELP NOWWWWWWW
Got air + impact gun?
Use a lubricating fluid?
If you have neither of these items and are stumped something you could do is put it back together, drive to a local shop that's not busy. Ask them to put it on a hoist and use their tools to loose it, then midly tighten it back up so you can get home and re-do the job at home with a loosened bolt. I can't see a shop charging too much more than a bribe of beer for this.
-Rik
-Rik
don 't hit it with a hammer I've had bad stuff happen from that. Try go renting the correct tool to get it removed. Yea u can use some wd 40 to help get it loose its not going to hurt anything.
Fawk those things...I busted both my boll joint boots with that chit. But it works, I guess...
WARNING: This is a trick that I use and do not suggest using it...
One trick I've used is place a jack stand underneath the brake rotor. Lower the jack down ever so slowly and let the spring compress a bit. Just a bit...then take a hammer to it...comes out ever time. Well, except when I had to use that fawking, BS-NO-good for nothing ball joint DESTROYER...end rant.
goodluck
goodluck
its common that that happens. Try the pickel fork (pictured above) or just take a crow bar and get good pressure on the top part of the control arm and start banging away with a hammer. Oh yes and do use some lubricant.
P.S. Don't take the castle screw of all the way just unscrew it enough so you can see a space between them (will help in preventing threading). Just listen for a click when you hammer and you ll know when its off
This method is foolproof, and there is a video
https://honda-tech.com/zerothread?id=887859
1. righty tighty lefty loosy.
2. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplegsr »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=887859</TD></TR></TABLE>
plaiskool
33
Aug 7, 2004 03:42 PM
